Hubitat states that this bulb is "confirmed to have worked but doesn't mean that it is guaranteed to work".
My situation: I correctly excluded the bulb from a previous network (Nexia) and performed a similar exclusion from Hubitat and a new inclusion into the C7 controller (basement location) . The bulb was about 4 feet from the C7 controller and worked fine with a simple rule, Alexa and Homekit.
I then moved the bulbed to my shed which is upstairs and outside about 40 feet away, Other Hubitat Z-Wave compatible devices (6 total) were already in use in the shed and about 10 others inside the house on the C7 network.
I screwed the bulb and it immediately failed. Repair attempts did not revive the bulb.
Question: Should I do a new exclusion/inclusion after the Simple Rule and Amazon and Homekit are removed?
I have 10 of these bulbs and would like to save $$.
