Linear actuation for 0-10V dimmer by temperature values
Hi,
I would like to use my 0-10V dimmer (to control heating circulation pump) linear between different temperatures. Of course the exact values will be determinded after testing.
But as ana example it would be like 0/1V (0 value) is at 0c degrees and when temperature drops to -20c it would give 10V (100 value). All the temperatures between would be like 5V in -10 etc.
Would that be possible with linear command or shoud I add rule after rule between different temperature grades?
Br.
Samuel
