Ligts do not turn on - Zigbee Dimmer with Yphix Zigbee Wirelesse Dimmer Switch 4 zones
Hello,
couldn't find any answer using Google so here it goes. Got my Hubitat yesterday and used the Hue Bridge Integration to integrate my existing setup. That setup mainly consists of dumb lamps with each a zigbee built-in-dimmer-switch in the powersocket (don't really know how you guys call it :wink: ). Furthermore I linked my Yphix Zigbee Wirelesse Dimmer Switch 4 zones (RGBgenie Button Controller) to the Hubitat (since it's not a friend-of-hue switch).
I set up this rule: Select Actions for [RGBgenie Button Controller] button 1 pushed
On: Buitenlamp keuken, but the light does not turn on. I've also tried with different lamps and/or extra commands. In the Hue iOS app it also does not show 'on' and the Hubitat-log says that the button is pushed (nothing else).
Separate issue what I encountered fiddling with this: also deleted the button-1-push and tried to add it again, but it does not show in the list of al de buttons (only see button 1 released held).
