You probably want to post this in the main thread for whichever homebridge plugin you're using. Doesn't appear to be the one linked to by @ogiewon because it uses MakerAPI and not a specialized app.
I got a successful config saved in makerAPI and that still doesn't work29/01/2022, 20:55:49] [Hubitat-MakerAPI] Initializing Hubitat-MakerAPI platform...
[29/01/2022, 20:55:49] TypeError: The "url" argument must be of type string. Received undefined
at new NodeError (node:internal/errors:371:5)
at validateString (node:internal/validators:119:11)
at Url.parse (node:url:169:3)
at Object.urlParse [as parse] (node:url:156:13)
at Object.init (/usr/local/lib/node_modules/homebridge-hubitat-makerapi/lib/util_http.js:96:26)
at Object.init (/usr/local/lib/node_modules/homebridge-hubitat-makerapi/lib/api-homebridge-hubitat-makerapi.js:66:19)
at new HE_ST_Platform (/usr/local/lib/node_modules/homebridge-hubitat-makerapi/index.js:122:15)
at /usr/local/lib/node_modules/homebridge/src/server.ts:440:40
at Array.forEach ()
at Server.loadPlatforms (/usr/local/lib/node_modules/homebridge/src/server.ts:372:27)
at Server.start (/usr/local/lib/node_modules/homebridge/src/server.ts:159:29)
Please use the thread linked to by @ogiewon to follow-up.
makerAPI actually freezes up homebridge
Then you've done something incorrect. Again, I would suggest following up on the thread @ogiewon linked to.
I can't work it out
I am using this and it says its ok but it just don't work
https://dantapps.github.io
I followed the link provided and I worked out how to copy and paste now to make it easier but it still freezes when I try
Well in my adventure last night I seem to have broken it all, nothing is working at the moment I think I will maybe reset and try again
