Coolness continues...
Just wondering, do you plan on postting your version in Developers>Code Share at some point? I expect users/developers would be interested.
A post was merged into an existing topic: Is there a simple way to track how long something is turned on in a day?"
Added a Boolean Hub Variable option to externally reset the timers. This way a simple RM rule can do that on a schedule. When the Boolean variable is set to true, that resets the timers. The app sets it back to false so it's ready for the next time.
I will, just got home from work, need to chill a bit then think about it. I want to add some other capabilities besides just switches.
Using Light Usage Table - selecting to write values to my log - is the app stripping out CR/LF?
If so, how do I resolve that?
Log looks like this:
And also, the variables created for the app are strings. How can I add strings to keep a running total for a device?
PS - the Boolean reset is just what I needed - thanks for that.
Parse it.
Neat.
If this could be adjusted to add a few more trackers, it might actually tempt me to make use of this instead of webcore for something.
I.e. Can total time on be upped to include "total time on today.... This week...... This calendar month.... This year..."
Interesting.
Yes, if using the tracker posted above. Just don't reset or use Auto reset and it will continuously accumulate Active time for the selected capability.
That's just a total total.
I'm curious to the the breakdown for Jan, Feb, week 1...week 43....
@bravenel I am trying to replicate the functionality you have within Rule Machine to "Create New Action" where clicking the green + takes you to another page within the app:
I know that the green + launches appButtonHandler but my question is how does appButtonHandler then redirect you to /doActPage? Within my version of appButtonHandler, I have tried calling the function that defines my dynamic page as well as defining a URL via string and returning it but its not working.
Or this for href:
String hrefLink(String pageName, String linkText, Map params = null) {
Integer pageNum = 55 // arbitrary number
"<input type='hidden' name='params_for_action_href_name|${pageName}|${pageNum}'><button type='button' name='_action_href_name|${pageName}|${pageNum}' style='cursor:pointer;color:#1A77C9;background-color: unset;border: none;'>${linkText}</button>"
Thanks Bruce. With your example realized it was a simple addition of href around the returned text from the call to buttonLink.
Hi Bruce @bravenel and folks. I've started using HE dashboards so decided to give this table a whirl. It's pretty cool - works like a champ. However, I also wanted the table to show a count of how many times the light turned on, and when it was last turned on. I also wanted a second table showing similar stats for doors/windows/contacts. I studied Bruce's clever little code and decided to take a whack at updating it myself. Seems to work although I confess I didn't spend a ton of time pressure testing it.
New tables look as follows:
And here's the code.
[EDIT]Found and squashed a few silly bugs - mostly in contacts table
and the variable was updated to include the count
* Usage and Count Table
* Copyright 2022 Hubitat, Inc. All Rights Reserved.
definition(
name: "Usage and Count Table",
namespace: "hubitat",
author: "Bruce Ravenel",
description: "Show Time and Frequency Usage of Lights and Contacts",
category: "Convenience",
iconUrl: "",
iconX2Url: ""
preferences {
page(name: "mainPage")
def mainPage() {
if(state.lights == null) state.lights = [:]
if(state.lightsList == null) state.lightsList = []
if(state.contacts == null) state.contacts = [:]
if(state.contactsList == null) state.contactsList = []
dynamicPage(name: "mainPage", title: "Usage and Count Table", uninstall: true, install: true) {
section {
input "lights", "capability.switch", title: "Select Lights to Measure Usage", multiple: true, submitOnChange: true, width: 4
lights.each {dev ->
if(!state.lights["$dev.id"]) {
state.lights["$dev.id"] = [start: dev.currentSwitch == "on" ? now() : 0, total: 0, var: "", time: "", count: 0]
state.lightsList += dev.id
input "resetVar", "enum", title: "Select Boolean Variable to Reset Light Timers and Counters", submitOnChange: true, width: 4, style: 'margin-left:10px',
options: getAllGlobalVars().findAll{it.value.type == "boolean"}.keySet().collect().sort{it.capitalize()}
if(lights) {
if(lights.id.sort() != state.lightsList.sort()) { //something was removed
state.lightsList = lights.id
Map newState = [:]
lights.each{d -> newState["$d.id"] = state.lights["$d.id"]}
state.lights = newState
updated()
paragraph displayLightsTable()
if(state.newVar) {
List vars = getAllGlobalVars().findAll{it.value.type == "string"}.keySet().collect().sort{it.capitalize()}
input "newVar", "enum", title: "Select Variable", submitOnChange: true, width: 4, options: vars, newLineAfter: true
if(newVar) {
state.lights[state.newVar].var = newVar
state.remove("newVar")
app.removeSetting("newVar")
paragraph "<script>{changeSubmit(this)}</script>"
} else if(state.remVar) {
state.lights[state.remVar].var = ""
state.remove("remVar")
input "refresh", "button", title: "Refresh Table", width: 2
input "reset", "button", title: "Reset Table", width: 2
section {
input "contacts", "capability.contactSensor", title: "Select Contacts to Measure Openings", multiple: true, submitOnChange: true, width: 4
contacts.each {dev ->
if(!state.contacts["$dev.id"]) {
state.contacts["$dev.id"] = [start: dev.currentContact == "open" ? now() : 0, total: 0, var: "", time: "", count: 0]
state.contactsList += dev.id
input "resetContactVar", "enum", title: "Select Boolean Variable to Reset Contact Timers and Counters", submitOnChange: true, width: 4, style: 'margin-left:10px',
if(contacts) {
if(contacts.id.sort() != state.contactsList.sort()) { //something was removed
state.contactsList = contacts.id
Map newState = [:]
contacts.each{d -> newState["$d.id"] = state.contacts["$d.id"]}
state.contacts = newState
updated()
paragraph displayContactsTable()
if(state.newContactVar) {
input "newContactVar", "enum", title: "Select Variable", submitOnChange: true, width: 4, options: vars, newLineAfter: true
if(newContactVar) {
state.contacts[state.newContactVar].var = newContactVar
state.remove("newContactVar")
app.removeSetting("newContactVar")
} else if(state.remContactVar) {
state.contacts[state.remContactVar].var = ""
state.remove("remContactVar")
input "refreshc", "button", title: "Refresh Table", width: 2
input "resetc", "button", title: "Reset Table", width: 2
String displayLightsTable() {
if(state.reset) {
def dev = lights.find{"$it.id" == state.reset}
state.lights[state.reset].start = dev.currentSwitch == "on" ? now() : 0
state.lights[state.reset].time = new Date().format("MM-dd-yyyy ${location.timeFormat == "12" ? "h:mm:ss a" : "HH:mm:ss"}")
state.lights[state.reset].total = 0
state.lights[state.reset].count = dev.currentSwitch == "on" ? 1 : 0
state.remove("reset")
String str = "<script src='https://code.iconify.design/iconify-icon/1.0.0/iconify-icon.min.js'></script>"
str += "<style>.mdl-data-table tbody tr:hover{background-color:inherit} .tstat-col td,.tstat-col th { padding:8px 8px;text-align:center;font-size:12px} .tstat-col td {font-size:15px }" +
"</style><div style='overflow-x:auto'><table class='mdl-data-table tstat-col' style=';border:2px solid black'>" +
"<thead><tr style='border-bottom:2px solid black'><th style='border-right:2px solid black'>Light</th>" +
"<th>Total On Time</th>" +
"<th>Total Count</th>" +
"<th>Reset</th>" +
"<th>Last Activation Time</th>" +
"<th>Last Reset Time</th>" +
"<th>Variable</th></tr></thead>"
lights.sort{it.displayName.toLowerCase()}.each {dev ->
int total = state.lights["$dev.id"].total / 1000
String thisVar = state.lights["$dev.id"].var
String count = state.lights["$dev.id"].count
String startstr = state.lights["$dev.id"].start ? new Date(state.lights["$dev.id"].start).format("MM-dd-yyyy ${location.timeFormat == "12" ? "h:mm:ss a" : "HH:mm:ss"}") : ""
int hours = total / 3600
total = total % 3600
int mins = total / 60
int secs = total % 60
String time = "$hours:${mins < 10 ? "0" : ""}$mins:${secs < 10 ? "0" : ""}$secs"
if(thisVar) setGlobalVar(thisVar, "$time $count")
String devLink = "<a href='/device/edit/$dev.id' target='_blank' title='Open Device Page for $dev'>$dev"
String reset = buttonLink("d$dev.id", "<iconify-icon icon='bx:reset'></iconify-icon>", "black", "20px")
String var = thisVar ? buttonLink("r$dev.id", thisVar, "purple") : buttonLink("n$dev.id", "Select", "green")
str += "<tr style='color:black'><td style='border-right:2px solid black'>$devLink</td>" +
"<td title='Switch usage time since last Reset' style='color:${dev.currentSwitch == "on" ? "green" : "red"}'>$time</td>" +
"<td title='Activation count since last Reset' style='color:${dev.currentSwitch == "on" ? "green" : "red"}'>$count</td>" +
"<td title='Reset Total Time and Total Count for $dev' style='padding:0px 0px'>$reset</td>" +
"<td title='Time of last Activation for $dev'>$startstr</td>" +
"<td title='Time of last Reset for $dev'>${state.lights["$dev.id"].time ?: ""}</td>" +
"<td title='${thisVar ? "Deselect $thisVar" : "Select String Hub Variable"}'>$var</td></tr>"
str += "</table></div>"
str
String displayContactsTable() {
if(state.contactreset) {
def dev = contacts.find{"$it.id" == state.contactreset}
state.contacts[state.contactreset].start = dev.currentContact == "open" ? now() : 0
state.contacts[state.contactreset].time = new Date().format("MM-dd-yyyy ${location.timeFormat == "12" ? "h:mm:ss a" : "HH:mm:ss"}")
state.contacts[state.contactreset].total = 0
state.contacts[state.contactreset].count = dev.currentContact == "open" ? 1 : 0
state.remove("contactreset")
"<thead><tr style='border-bottom:2px solid black'><th style='border-right:2px solid black'>Contact</th>" +
"<th>Total Open Time</th>" +
"<th>Reset</th>" +
"<th>Last Open Time</th>" +
contacts.sort{it.displayName.toLowerCase()}.each {dev ->
int total = state.contacts["$dev.id"].total / 1000
String thisVar = state.contacts["$dev.id"].var
String count = state.contacts["$dev.id"].count
String startstr = state.contacts["$dev.id"].start ? new Date(state.contacts["$dev.id"].start).format("MM-dd-yyyy ${location.timeFormat == "12" ? "h:mm:ss a" : "HH:mm:ss"}") : ""
String reset = buttonLink("e$dev.id", "<iconify-icon icon='bx:reset'></iconify-icon>", "black", "20px")
String var = thisVar ? buttonLink("s$dev.id", thisVar, "purple") : buttonLink("o$dev.id", "Select", "green")
"<td title='Contact open time since last Reset' style='color:${dev.currentContact == "open" ? "green" : "red"}'>$time</td>" +
"<td title='Open count since last Reset' style='color:${dev.currentContact == "open" ? "green" : "red"}'>$count</td>" +
"<td title='Time of last Open for $dev'>$startstr</td>" +
"<td title='Time of last Reset for $dev'>${state.contacts["$dev.id"].time ?: ""}</td>" +
str
String buttonLink(String btnName, String linkText, color = "#1A77C9", font = "15px") {
"<div class='form-group'><input type='hidden' name='${btnName}.type' value='button'></div><div><div class='submitOnChange' onclick='buttonClick(this)' style='color:$color;cursor:pointer;font-size:$font'>$linkText</div></div><input type='hidden' name='settings[$btnName]' value=''>"
void appButtonHandler(btn) {
if(btn == "reset") resetTimers()
else if(btn == "resetc") resetContactTimers()
else if(btn == "refresh") {
state.lights.each{k, v ->
def dev = lights.find{"$it.id" == k}
if(dev.currentSwitch == "on") {
state.lights[k].total += now() - state.lights[k].start
state.lights[k].start = now()
} else if(btn =="refreshc") {
state.contacts.each{k, v ->
def dev = contacts.find{"$it.id" == k}
if(dev.currentContact == "open") {
state.contacts[k].total += now() - state.contacts[k].start
state.contacts[k].start = now()
} else if(btn.startsWith("n")) state.newVar = btn.minus("n")
else if(btn.startsWith("r")) state.remVar = btn.minus("r")
else if(btn.startsWith("o")) state.newContactVar = btn.minus("o")
else if(btn.startsWith("s")) state.remContactVar = btn.minus("s")
else if(btn.startsWith('e')) state.contactreset = btn.minus("e")
else if(btn.startsWith('d')) state.reset = btn.minus("d")
else log.warn "Unrecognized button pressed"
def updated() {
unsubscribe()
initialize()
def installed() {
def uninstalled() {
unsubscribe()
void initialize() {
subscribe(lights, "switch.on", "onHandler")
subscribe(lights, "switch.off", "offHandler")
if(resetVar) {
subscribe(location, "variable:${resetVar}.true", resetTimers)
setGlobalVar(resetVar, false)
// subscribe(contacts, "contact.open", "openHandler")
// subscribe(contacts, "contact.closed", "closeHandler")
contacts?.each { device ->
subscribe(device, "contact", "contactHandler")
if(resetContactVar) {
subscribe(location, "variable:${resetContactVar}.true", resetContactTimers)
setGlobalVar(resetContactVar, false)
void contactHandler(evt) {
def value = evt.value
if (value == "open") openHandler(evt)
else if (value== "closed") closeHandler(evt)
void onHandler(evt) {
if ( state.lights[evt.device.id] ) {
state.lights[evt.device.id].start = now()
state.lights[evt.device.id].count++
String startstr = new Date(state.lights[evt.device.id].start).format("MM-dd-yyyy ${location.timeFormat == "12" ? "h:mm:ss a" : "HH:mm:ss"}")
log.info "device ${evt.device.displayName} turned on at $startstr"
void offHandler(evt) {
state.lights[evt.device.id].total += now() - state.lights[evt.device.id].start
String thisVar = state.lights[evt.device.id].var
int total = state.lights[evt.device.id].total / 1000
String thisTime = "$hours:${mins < 10 ? "0" : ""}$mins:${secs < 10 ? "0" : ""}$secs"
log.info "device ${evt.device.displayName} total = $thisTime"
if(thisVar) setGlobalVar(thisVar, thisTime)
void openHandler(evt) {
if ( state.contacts[evt.device.id] ) {
state.contacts[evt.device.id].start = now()
state.contacts[evt.device.id].count++
String startstr = new Date(state.contacts[evt.device.id].start).format("MM-dd-yyyy ${location.timeFormat == "12" ? "h:mm:ss a" : "HH:mm:ss"}")
log.info "device ${evt.device.displayName} opened at $startstr"
void closeHandler(evt) {
state.contacts[evt.device.id].total += now() - state.contacts[evt.device.id].start
String thisVar = state.contacts[evt.device.id].var
int total = state.contacts[evt.device.id].total / 1000
void resetTimers(evt = null) {
if ( dev ) {
state.lights[k].start = dev.currentSwitch == "on" ? now() : 0
state.lights[k].time = new Date().format("MM-dd-yyyy ${location.timeFormat == "12" ? "h:mm:ss a" : "HH:mm:ss"}")
state.lights[k].total = 0
state.lights[k].count = dev.currentSwitch == "on" ? 1 : 0
if(resetVar) setGlobalVar(resetVar, false)
void resetContactTimers(evt = null) {
if ( dev ) {
state.contacts[k].start = dev.currentContact == "open" ? now() : 0
state.contacts[k].time = new Date().format("MM-dd-yyyy ${location.timeFormat == "12" ? "h:mm:ss a" : "HH:mm:ss"}")
state.contacts[k].total = 0
state.contacts[k].count = dev.currentContact == "open" ? 1 : 0
if(resetContactVar) setGlobalVar(resetContactVar, false)
@kewashi Thanks for the modified version of this app. Very useful.
@kewashi,
Thank you for the modified app.
In addition to the last turned on time, would it be possible to have last turned off time as both will be very useful?
Sure — it’s just code. I don’t want the extra column so I won’t make it but you should go for it. The groovy code is fairly straightforward to adapt. If you’re not a coder let me know and I will put it in my queue to help you out.
