Lights go red on contact change
I'd just define a local boolean (true/false) variable, then do basically what you were doing before, except capture the on/off state to this variable (so you know what it was before you changed anything), turn the bulb on and capture its state (so RM gets all color/level attributes, etc.), change it to what you want (red at 50%; I only did 50% in my example because I used a dimmer and not a bulb), then restore it (so it will get all the correct color/level states), and turn it off it was off originally (per your variable).
Here is one way you could do that:
