I noticed the Sylvania Smart Switch was included in the driver list. I still cannot get it to include. Did a reset and also tried removing battery. Still does not see it.
Is this for something else?
no, you have to wake it up to get it to join, put hub in discovery mode, then hold down buttons 2 and 3 on the switch until the thing blinks
Yes I have already tried that. Holding down 1 & 3 according to the manual does a reset. Light blinks every second for 10 seconds and then gets faster and goes off. Holding down 2 & 3 does nothing.
EDIT: Manual says the light will be a continuous blinking blue when in pairing mode. This condition is never achieved by doing a reset or removing and re-installing battery so there is something incorrect about getting it into pairing mode. Wrong procedure.
i just unpaired and paired mine...
factory reset it
place hub in discover mode...
hold down buttons 2 and 3, led should start flashing yellow, release and it will be discovered...
button 2 is upper right, button 3 is lower left.
Nope. Nothing is working as you said. I must have a dud. No yellow blinking light at all. Reset it again and then tried the buttons 2 & 3 and nothing.
Last ditch effort. Try factory reset, then pull the battery for 20 seconds
Replace battery and then hub in discovery mode
Then put the device into pairing mode.
Sometimes works with the finicky Zigbee devices
Nope. Definitely a dud. I will send it back. Thanks for the help.
I finally got mine paired. First time hub locked up, found devise but never got past initializing. Would never see the switch again so I removed the battery for about 30 seconds, held down buttons 1,4 for 10 seconds until reset, then held buttons 2,3 down until it started blinking orange and was immediately found. It was a pain, took almost half hour to finally pair.
Hope this works for you
These will not pair unless buttons 2 and 3 are held and the device is blinking yellow, if the device is blinking green, then factory reset it using buttons 1 and 4, then place hub in discovery and hols 2 and 3 until yellow flashing...
This isn't anything to do with Hubitat, same procedure is required when joining to the osram/Sylvania hub.
I had been having issues getting this button to pair for me. Pressing buttons 2 & 3 and releasing them as soon as the light started flashing orange worked instantly for me. So glad I found these buttons.
