I saw a post a while back but cannot find it again. I am trying to make a rule that checks and corrects if a light in a group is supposed to be on but for some reason did not go on.
At that point I would want it to be turned on/off to match what the rest of the group on/off state is at.
Anyone seen this or have a way to do this? thanks
Probably better to figure out why the light isn't coming on. Weak mesh or problem with the bulb? Do your lights support group messaging? It might help to ensure the messages are sent to all lights.
Yes I have that turned on but just did that this AM so may fix the issue. The light is the farthest away but I have the bulbs in a circular pattern. I have them back on the hue bridge so will see. Thanks for the reply.
I also have a couple of zigbee power plugs scattered in the mix also.
Ah, then Group messaging in Hubitat Groups wonβt do anything. Hue Bridge does its own group messaging.
In fact, if all your lights are back in the Heu Bridge, you should then be using Hue Groups, not HE Groups.
Oh, I did not know you should use hue groups or that HE groups will not work for this situation.
Is that the same as rooms? Not seeing groups in the app.
EDIT: Created two rooms and selected them in the Hue Bridge Integration and they showed up as devices.
That is the one I have been searching for! It looks a little different. I think it is the Off command in the true action? Thanks
