So I made this very simple rule. Basically when I walk into the bathroom and press the Off button once, it should turn off. But if the light is already off, it should turn it on to 20%. (this is so I can easily use the light without blinding myself in the middle of the night)
The following rule keeps dimming the light down, then immediately setting it back to 20%. I don't get it.
The main log events list. He's suggesting it's another app or device that is doing it. You might need to turn some logging on for other devices (like that button) and apps.
So based on that log, It thinks the light is off. So it MUST be that the Inovelli is first doing it's own function locally (turning off the light) and then the rule is triggered, which now sees the light as off.
Is it possible to disable the default function of local button press?
Well that SUCKS! cause if i turn off local control, now I cannot dim up/down manually either.....i couldn't even create a rule to do so cause there is no true "held" functionality.
Rule executes...sets dimmer to 20.
Same rule executes which is SUPPOSED to turn off the switch if it's on...but instead the power reporting goes up to 30?!?!?! (and i see the light get brighter)
Is this an LZW30 or an LZW30-SN? If the latter, it will send "scene" (button) events for all taps plus holds and releases (they're just named and numbered super-awkwardly if you use Inovelli's driver). If the former, disabling the relay will severely limit your options outside of Z-Wave Association.
