Not at the moment AFAIK.
Add it to the āweāll get around to it someday maybeā list?
Get the latest from my github. I think I got everything. Let me know if you run into any issues.
Yup, that works - although I can't set the colour from Alexa (or from the device page)
ALEXA
You would need a skill to set color from alexa. I donāt control my Lifx bulb through habitat. I use the direct Lifx skill on my echo for voice control.
DEVICE PAGE
At least at the time that I initially wrote this driver, setColor was not yet supported but on the hubitat to do list for any driver using the methodā¦ When I get feedback that it is live I will attempt to add that functionality.
Actually looking back at the old post by @mike.maxwell it may be added on 707.
@mike.maxwell can you confirm that setcolor is live.
Ah, okay. I just assumed that it was supposed to work. Not a problem in any way
yes, live
Great, thanks.
@rob, Iāll work on it this week. Donāt set your expectations too high because this was my first stab at setting up a color device and itās a little more complicated than I expected. I havenāt found a set guideline in ST or hubitat yet, so basically Iāll be testing against my Hue devices and trying to mimic on this Lifx driver.
setColor should now work according to Hubitat standards. See update notes for details.
Great, Iāll give it a go tomorrow.
Nope, still not working for me
[dev:35](http://192.168.1.106/logs#dev35)2018-04-19 01:10:20.319:errorNo such property: hue for class: groovy.json.internal.CharSequenceValue on line 304
[dev:35](http://192.168.1.106/logs#dev35)2018-04-19 01:10:20.283:debugLIFX-GoG -- null -- Begin setting groups color to red.
What are u using to set the color?
It supports
setColor(map)
Where map is [hue:, saturation:, level:]
Ah, okay, that wasn't clear, I assumed it was just a name. What are the ranges of those values?
0-100
Had to change them to match hubitatās methodology with the hue integration
There might be options missingā¦just let me know what commands donāt work and what app you are sending the command from
The map settings didn't copy correctly in my last post. See quote above.
Aha, that worked! At least from the device page - no idea what I'd need to do for Alexa
Alexa wonāt control color on hubitat devicesā¦only on/off and brightness. For color you would need to use the lifx skill.
Fair enough
