C8Pro running 2.5.0.126
Suddenly getting tons of "rssi" logs from a Lifx bulb that's been in place for many years. It's not even on. Did something change in 2.5.0?
dev:27962026-04-30 09:22:22.785 PMinfoReading rssi is -72dBm
dev:27962026-04-30 09:18:22.844 PMinfoReading rssi is -70dBm
dev:27962026-04-30 09:17:04.113 PMinfoReading rssi is -69dBm
dev:27962026-04-30 09:16:22.830 PMinfoReading rssi is -70dBm
dev:27962026-04-30 09:14:22.726 PMinfoReading rssi is -72dBm
dev:27962026-04-30 09:12:22.698 PMinfoReading rssi is -71dBm
dev:27962026-04-30 09:10:22.793 PMinfoReading rssi is -73dBm
dev:27962026-04-30 09:06:22.654 PMinfoReading rssi is -72dBm
dev:27962026-04-30 09:04:22.890 PMinfoReading rssi is -71dBm
dev:27962026-04-30 09:02:22.740 PMinfoReading rssi is -73dBm
dev:27962026-04-30 08:56:22.795 PMinfoReading rssi is -72dBm
dev:27962026-04-30 08:54:22.670 PMinfoReading rssi is -71dBm
dev:27962026-04-30 08:52:22.776 PMinfoReading rssi is -72dBm
dev:27962026-04-30 08:48:22.730 PMinfoReading rssi is -73dBm
dev:27962026-04-30 08:46:22.828 PMinfoReading rssi is -72dBm
dev:27962026-04-30 08:44:22.802 PMinfoReading rssi is -71dBm
dev:27962026-04-30 08:40:22.778 PMinfoReading rssi is -72dBm
dev:27962026-04-30 08:38:22.665 PMinfoReading rssi is -73dBm
dev:27962026-04-30 08:28:22.790 PMinfoReading rssi is -72dBm
dev:27962026-04-30 08:24:22.763 PMinfoReading rssi is -71dBm
dev:27962026-04-30 07:46:22.822 PMinfoReading rssi is -72dBm
dev:27962026-04-30 07:44:22.774 PMinfoReading rssi is -73dBm
dev:27962026-04-30 07:36:22.734 PMinfoReading rssi is -72dBm
dev:27962026-04-30 07:34:22.817 PMinfoReading rssi is -73dBm
dev:27962026-04-30 07:20:22.713 PMinfoReading rssi is -72dBm
dev:27962026-04-30 07:18:22.702 PMinfoReading rssi is -71dBm
dev:27962026-04-30 07:16:22.789 PMinfoReading rssi is -72dBm
dev:27962026-04-30 07:14:22.664 PMinfoReading rssi is -71dBm
dev:27962026-04-30 07:10:22.780 PMinfoReading rssi is -72dBm
dev:27962026-04-30 07:08:22.726 PMinfoReading rssi is -74dBm
dev:27962026-04-30 07:02:22.679 PMinfoReading rssi is -72dBm
dev:27962026-04-30 07:00:22.663 PMinfoReading rssi is -73dBm
dev:27962026-04-30 06:58:22.765 PMinfoReading rssi is -71dBm
dev:27962026-04-30 06:54:22.839 PMinfoReading rssi is -72dBm
dev:27962026-04-30 06:50:22.703 PMinfoReading rssi is -71dBm
dev:27962026-04-30 06:36:22.827 PMinfoReading rssi is -72dBm
dev:27962026-04-30 06:32:22.798 PMinfoReading rssi is -73dBm
dev:27962026-04-30 06:28:22.848 PMinfoReading rssi is -72dBm
Edit: Actually a lot o Lifx bulbs are suddenly reporting rssi info. This is new AFAIK.
Have you checked to see is debug logging is on for the device? Maybe it accidentally got turned on?
Yes and reconfirmed just now. Debug logging is turned off. Pretty sure the new release changed something with LIFX bulbs. Anyone else seeing this?
Thanks Rick @rlithgow1 for tagging Bryan. @bcopeland. My logs are being filled by rssi entries. Last couple of hours:
dev:28012026-05-01 05:56:22.769 AMinfoStudy Ceiling 6 rssi is -49dBm
dev:28002026-05-01 05:56:22.764 AMinfoStudy Ceiling 4 rssi is -46dBm
dev:28082026-05-01 05:56:22.723 AMinfoStudy Ceiling 2 rssi is -62dBm
dev:27962026-05-01 05:56:22.716 AMinfoReading rssi is -69dBm
dev:28052026-05-01 05:56:22.712 AMinfoLiving Room Floor Lamp rssi is -30dBm
dev:28072026-05-01 05:56:22.655 AMinfoStudy Torch Light rssi is -40dBm
dev:28032026-05-01 05:54:22.738 AMinfoStudy Ceiling 8 rssi is -66dBm
dev:27972026-05-01 05:54:22.746 AMinfoStudy Ceiling 5 rssi is -52dBm
dev:28022026-05-01 05:54:22.737 AMinfoStudy Ceiling 3 rssi is -69dBm
dev:27992026-05-01 05:54:22.735 AMinfoStudy Ceiling 1 rssi is -67dBm
dev:28052026-05-01 05:54:22.666 AMinfoLiving Room Floor Lamp rssi is -31dBm
dev:28072026-05-01 05:54:22.645 AMinfoStudy Torch Light rssi is -39dBm
dev:28082026-05-01 05:54:22.641 AMinfoStudy Ceiling 2 rssi is -64dBm
dev:28012026-05-01 05:52:22.722 AMinfoStudy Ceiling 6 rssi is -48dBm
dev:27992026-05-01 05:52:22.687 AMinfoStudy Ceiling 1 rssi is -69dBm
dev:28082026-05-01 05:52:22.686 AMinfoStudy Ceiling 2 rssi is -62dBm
dev:28072026-05-01 05:52:22.639 AMinfoStudy Torch Light rssi is -40dBm
dev:27982026-05-01 05:50:22.828 AMinfoStudy Ceiling 7 rssi is -55dBm
dev:28002026-05-01 05:50:22.826 AMinfoStudy Ceiling 4 rssi is -47dBm
dev:27972026-05-01 05:50:22.816 AMinfoStudy Ceiling 5 rssi is -53dBm
dev:28082026-05-01 05:50:22.679 AMinfoStudy Ceiling 2 rssi is -61dBm
dev:28032026-05-01 05:50:22.679 AMinfoStudy Ceiling 8 rssi is -65dBm
dev:27992026-05-01 05:48:22.762 AMinfoStudy Ceiling 1 rssi is -68dBm
dev:28082026-05-01 05:48:22.758 AMinfoStudy Ceiling 2 rssi is -63dBm
dev:28032026-05-01 05:48:22.758 AMinfoStudy Ceiling 8 rssi is -66dBm
dev:28002026-05-01 05:48:22.712 AMinfoStudy Ceiling 4 rssi is -49dBm
dev:27972026-05-01 05:48:22.703 AMinfoStudy Ceiling 5 rssi is -52dBm
dev:28072026-05-01 05:48:22.653 AMinfoStudy Torch Light rssi is -39dBm
dev:28032026-05-01 05:46:22.871 AMinfoStudy Ceiling 8 rssi is -67dBm
dev:27962026-05-01 05:46:22.865 AMinfoReading rssi is -70dBm
dev:27992026-05-01 05:46:22.858 AMinfoStudy Ceiling 1 rssi is -67dBm
dev:28082026-05-01 05:46:22.850 AMinfoStudy Ceiling 2 rssi is -62dBm
dev:28012026-05-01 05:46:22.691 AMinfoStudy Ceiling 6 rssi is -47dBm
dev:27972026-05-01 05:46:22.685 AMinfoStudy Ceiling 5 rssi is -51dBm
dev:27982026-05-01 05:46:22.680 AMinfoStudy Ceiling 7 rssi is -54dBm
dev:28042026-05-01 05:46:22.676 AMinfoStudy Ceiling 9 rssi is -52dBm
dev:28062026-05-01 05:46:22.644 AMinfoFamily Room Torch rssi is -32dBm
dev:28072026-05-01 05:46:22.641 AMinfoStudy Torch Light rssi is -38dBm
dev:27992026-05-01 05:44:22.845 AMinfoStudy Ceiling 1 rssi is -66dBm
dev:28022026-05-01 05:44:22.842 AMinfoStudy Ceiling 3 rssi is -70dBm
dev:27962026-05-01 05:44:22.838 AMinfoReading rssi is -71dBm
dev:28082026-05-01 05:44:22.837 AMinfoStudy Ceiling 2 rssi is -64dBm
dev:28052026-05-01 05:44:22.829 AMinfoLiving Room Floor Lamp rssi is -30dBm
dev:28032026-05-01 05:44:22.829 AMinfoStudy Ceiling 8 rssi is -64dBm
dev:27982026-05-01 05:44:22.779 AMinfoStudy Ceiling 7 rssi is -52dBm
dev:27972026-05-01 05:44:22.774 AMinfoStudy Ceiling 5 rssi is -50dBm
dev:28002026-05-01 05:44:22.765 AMinfoStudy Ceiling 4 rssi is -48dBm
dev:28062026-05-01 05:44:22.645 AMinfoFamily Room Torch rssi is -30dBm
dev:28072026-05-01 05:44:22.641 AMinfoStudy Torch Light rssi is -39dBm
dev:28012026-05-01 05:42:22.866 AMinfoStudy Ceiling 6 rssi is -48dBm
dev:27962026-05-01 05:42:22.828 AMinfoReading rssi is -70dBm
dev:27992026-05-01 05:42:22.824 AMinfoStudy Ceiling 1 rssi is -65dBm
dev:28032026-05-01 05:42:22.818 AMinfoStudy Ceiling 8 rssi is -65dBm
dev:28082026-05-01 05:42:22.817 AMinfoStudy Ceiling 2 rssi is -62dBm
dev:27982026-05-01 05:42:22.655 AMinfoStudy Ceiling 7 rssi is -53dBm
dev:28012026-05-01 05:40:22.877 AMinfoStudy Ceiling 6 rssi is -46dBm
dev:27972026-05-01 05:40:22.874 AMinfoStudy Ceiling 5 rssi is -52dBm
dev:27982026-05-01 05:40:22.866 AMinfoStudy Ceiling 7 rssi is -54dBm
dev:28082026-05-01 05:40:22.715 AMinfoStudy Ceiling 2 rssi is -63dBm
dev:27992026-05-01 05:40:22.708 AMinfoStudy Ceiling 1 rssi is -67dBm
dev:27962026-05-01 05:40:22.712 AMinfoReading rssi is -71dBm
dev:28032026-05-01 05:40:22.708 AMinfoStudy Ceiling 8 rssi is -66dBm
dev:28042026-05-01 05:40:22.697 AMinfoStudy Ceiling 9 rssi is -50dBm
dev:28072026-05-01 05:40:22.689 AMinfoStudy Torch Light rssi is -40dBm
dev:27972026-05-01 05:38:22.838 AMinfoStudy Ceiling 5 rssi is -50dBm
dev:28042026-05-01 05:38:22.838 AMinfoStudy Ceiling 9 rssi is -49dBm
dev:27982026-05-01 05:38:22.824 AMinfoStudy Ceiling 7 rssi is -51dBm
dev:28012026-05-01 05:38:22.821 AMinfoStudy Ceiling 6 rssi is -47dBm
dev:28022026-05-01 05:38:22.704 AMinfoStudy Ceiling 3 rssi is -69dBm
dev:28082026-05-01 05:38:22.699 AMinfoStudy Ceiling 2 rssi is -61dBm
dev:27992026-05-01 05:38:22.694 AMinfoStudy Ceiling 1 rssi is -69dBm
dev:27962026-05-01 05:38:22.693 AMinfoReading rssi is -70dBm
dev:28032026-05-01 05:38:22.691 AMinfoStudy Ceiling 8 rssi is -65dBm
dev:28062026-05-01 05:38:22.642 AMinfoFamily Room Torch rssi is -31dBm
dev:28022026-05-01 05:36:22.821 AMinfoStudy Ceiling 3 rssi is -67dBm
dev:28082026-05-01 05:36:22.820 AMinfoStudy Ceiling 2 rssi is -65dBm
dev:28002026-05-01 05:36:22.734 AMinfoStudy Ceiling 4 rssi is -46dBm
dev:27972026-05-01 05:36:22.731 AMinfoStudy Ceiling 5 rssi is -51dBm
dev:28042026-05-01 05:36:22.731 AMinfoStudy Ceiling 9 rssi is -53dBm
dev:28062026-05-01 05:36:22.642 AMinfoFamily Room Torch rssi is -32dBm
dev:28032026-05-01 05:34:22.967 AMinfoStudy Ceiling 8 rssi is -66dBm
dev:27992026-05-01 05:34:22.858 AMinfoStudy Ceiling 1 rssi is -68dBm
dev:28022026-05-01 05:34:22.764 AMinfoStudy Ceiling 3 rssi is -66dBm
dev:28082026-05-01 05:34:22.764 AMinfoStudy Ceiling 2 rssi is -66dBm
dev:27962026-05-01 05:34:22.763 AMinfoReading rssi is -71dBm
dev:27982026-05-01 05:34:22.700 AMinfoStudy Ceiling 7 rssi is -54dBm
dev:28042026-05-01 05:34:22.700 AMinfoStudy Ceiling 9 rssi is -52dBm
dev:28002026-05-01 05:34:22.694 AMinfoStudy Ceiling 4 rssi is -47dBm
dev:28012026-05-01 05:34:22.694 AMinfoStudy Ceiling 6 rssi is -45dBm
dev:28062026-05-01 05:34:22.654 AMinfoFamily Room Torch rssi is -31dBm
dev:28032026-05-01 05:32:22.844 AMinfoStudy Ceiling 8 rssi is -65dBm
dev:28002026-05-01 05:32:22.789 AMinfoStudy Ceiling 4 rssi is -46dBm
dev:27972026-05-01 05:32:22.783 AMinfoStudy Ceiling 5 rssi is -53dBm
dev:28042026-05-01 05:32:22.781 AMinfoStudy Ceiling 9 rssi is -53dBm
dev:27982026-05-01 05:32:22.781 AMinfoStudy Ceiling 7 rssi is -53dBm
dev:28022026-05-01 05:32:22.750 AMinfoStudy Ceiling 3 rssi is -67dBm
dev:27992026-05-01 05:32:22.750 AMinfoStudy Ceiling 1 rssi is -70dBm
dev:27962026-05-01 05:32:22.748 AMinfoReading rssi is -70dBm
dev:28062026-05-01 05:32:22.644 AMinfoFamily Room Torch rssi is -33dBm
dev:28022026-05-01 05:30:22.844 AMinfoStudy Ceiling 3 rssi is -66dBm
dev:27992026-05-01 05:30:22.837 AMinfoStudy Ceiling 1 rssi is -69dBm
dev:28082026-05-01 05:30:22.844 AMinfoStudy Ceiling 2 rssi is -64dBm
dev:27962026-05-01 05:30:22.842 AMinfoReading rssi is -74dBm
dev:28032026-05-01 05:30:22.836 AMinfoStudy Ceiling 8 rssi is -67dBm
dev:27972026-05-01 05:30:22.827 AMinfoStudy Ceiling 5 rssi is -51dBm
dev:28012026-05-01 05:30:22.823 AMinfoStudy Ceiling 6 rssi is -46dBm
dev:27972026-05-01 05:28:22.854 AMinfoStudy Ceiling 5 rssi is -54dBm
dev:28012026-05-01 05:28:22.850 AMinfoStudy Ceiling 6 rssi is -44dBm
dev:28042026-05-01 05:28:22.751 AMinfoStudy Ceiling 9 rssi is -52dBm
dev:28052026-05-01 05:28:22.723 AMinfoLiving Room Floor Lamp rssi is -29dBm
dev:27962026-05-01 05:28:22.714 AMinfoReading rssi is -68dBm
dev:28032026-05-01 05:28:22.713 AMinfoStudy Ceiling 8 rssi is -64dBm
dev:27972026-05-01 05:26:22.857 AMinfoStudy Ceiling 5 rssi is -52dBm
dev:28052026-05-01 05:26:22.801 AMinfoLiving Room Floor Lamp rssi is -30dBm
dev:28022026-05-01 05:26:22.801 AMinfoStudy Ceiling 3 rssi is -65dBm
dev:27992026-05-01 05:26:22.748 AMinfoStudy Ceiling 1 rssi is -67dBm
dev:28032026-05-01 05:26:22.745 AMinfoStudy Ceiling 8 rssi is -65dBm
dev:27962026-05-01 05:26:22.746 AMinfoReading rssi is -72dBm
dev:28082026-05-01 05:26:22.711 AMinfoStudy Ceiling 2 rssi is -65dBm
dev:28042026-05-01 05:24:22.928 AMinfoStudy Ceiling 9 rssi is -53dBm
dev:27972026-05-01 05:24:22.826 AMinfoStudy Ceiling 5 rssi is -54dBm
dev:28012026-05-01 05:24:22.826 AMinfoStudy Ceiling 6 rssi is -45dBm
dev:28022026-05-01 05:24:22.796 AMinfoStudy Ceiling 3 rssi is -67dBm
dev:28082026-05-01 05:24:22.793 AMinfoStudy Ceiling 2 rssi is -63dBm
dev:28032026-05-01 05:24:22.793 AMinfoStudy Ceiling 8 rssi is -66dBm
dev:27992026-05-01 05:24:22.791 AMinfoStudy Ceiling 1 rssi is -69dBm
dev:28052026-05-01 05:24:22.790 AMinfoLiving Room Floor Lamp rssi is -29dBm
dev:27972026-05-01 05:22:22.714 AMinfoStudy Ceiling 5 rssi is -52dBm
dev:28012026-05-01 05:22:22.711 AMinfoStudy Ceiling 6 rssi is -44dBm
dev:27962026-05-01 05:22:22.680 AMinfoReading rssi is -71dBm
dev:28082026-05-01 05:22:22.679 AMinfoStudy Ceiling 2 rssi is -64dBm
dev:27992026-05-01 05:22:22.672 AMinfoStudy Ceiling 1 rssi is -67dBm
dev:28062026-05-01 05:22:22.662 AMinfoFamily Room Torch rssi is -31dBm
dev:27972026-05-01 05:20:22.692 AMinfoStudy Ceiling 5 rssi is -51dBm
dev:28022026-05-01 05:20:22.687 AMinfoStudy Ceiling 3 rssi is -66dBm
dev:27962026-05-01 05:20:22.679 AMinfoReading rssi is -72dBm
dev:28052026-05-01 05:20:22.677 AMinfoLiving Room Floor Lamp rssi is -28dBm
dev:27972026-05-01 05:18:22.780 AMinfoStudy Ceiling 5 rssi is -53dBm
dev:28012026-05-01 05:18:22.779 AMinfoStudy Ceiling 6 rssi is -45dBm
dev:28022026-05-01 05:18:22.751 AMinfoStudy Ceiling 3 rssi is -67dBm
dev:27962026-05-01 05:18:22.740 AMinfoReading rssi is -71dBm
dev:28062026-05-01 05:18:22.639 AMinfoFamily Room Torch rssi is -32dBm
dev:28072026-05-01 05:18:22.639 AMinfoStudy Torch Light rssi is -39dBm
dev:28022026-05-01 05:17:04.150 AMinfoStudy Ceiling 3 rssi is -66dBm
dev:27992026-05-01 05:17:04.147 AMinfoStudy Ceiling 1 rssi is -68dBm
dev:27962026-05-01 05:17:04.145 AMinfoReading rssi is -72dBm
dev:27972026-05-01 05:17:04.063 AMinfoStudy Ceiling 5 rssi is -51dBm
dev:28002026-05-01 05:17:04.056 AMinfoStudy Ceiling 4 rssi is -47dBm
dev:28072026-05-01 05:17:04.037 AMinfoStudy Torch Light rssi is -38dBm
dev:28062026-05-01 05:17:04.036 AMinfoFamily Room Torch rssi is -31dBm
dev:28022026-05-01 05:16:22.832 AMinfoStudy Ceiling 3 rssi is -67dBm
dev:28082026-05-01 05:16:22.743 AMinfoStudy Ceiling 2 rssi is -65dBm
dev:28032026-05-01 05:16:22.735 AMinfoStudy Ceiling 8 rssi is -65dBm
dev:28002026-05-01 05:16:22.692 AMinfoStudy Ceiling 4 rssi is -46dBm
dev:27972026-05-01 05:16:22.692 AMinfoStudy Ceiling 5 rssi is -52dBm
dev:27982026-05-01 05:16:22.690 AMinfoStudy Ceiling 7 rssi is -54dBm
dev:28062026-05-01 05:16:22.680 AMinfoFamily Room Torch rssi is -32dBm
dev:27982026-05-01 05:14:22.860 AMinfoStudy Ceiling 7 rssi is -53dBm
dev:28002026-05-01 05:14:22.858 AMinfoStudy Ceiling 4 rssi is -48dBm
dev:27992026-05-01 05:14:22.816 AMinfoStudy Ceiling 1 rssi is -69dBm
dev:28082026-05-01 05:14:22.727 AMinfoStudy Ceiling 2 rssi is -64dBm
dev:27962026-05-01 05:14:22.725 AMinfoReading rssi is -73dBm
dev:28022026-05-01 05:14:22.720 AMinfoStudy Ceiling 3 rssi is -66dBm
dev:28032026-05-01 05:14:22.714 AMinfoStudy Ceiling 8 rssi is -64dBm
dev:28012026-05-01 05:12:22.841 AMinfoStudy Ceiling 6 rssi is -44dBm
dev:28032026-05-01 05:12:22.822 AMinfoStudy Ceiling 8 rssi is -65dBm
dev:28022026-05-01 05:12:22.818 AMinfoStudy Ceiling 3 rssi is -67dBm
dev:28082026-05-01 05:12:22.809 AMinfoStudy Ceiling 2 rssi is -65dBm
dev:28012026-05-01 05:10:22.832 AMinfoStudy Ceiling 6 rssi is -45dBm
dev:28002026-05-01 05:10:22.828 AMinfoStudy Ceiling 4 rssi is -47dBm
dev:27972026-05-01 05:10:22.823 AMinfoStudy Ceiling 5 rssi is -51dBm
dev:28032026-05-01 05:10:22.790 AMinfoStudy Ceiling 8 rssi is -66dBm
dev:27962026-05-01 05:10:22.785 AMinfoReading rssi is -72dBm
dev:28062026-05-01 05:10:22.641 AMinfoFamily Room Torch rssi is -31dBm
dev:27972026-05-01 05:08:22.812 AMinfoStudy Ceiling 5 rssi is -52dBm
dev:28002026-05-01 05:08:22.812 AMinfoStudy Ceiling 4 rssi is -48dBm
dev:28012026-05-01 05:08:22.809 AMinfoStudy Ceiling 6 rssi is -44dBm
dev:28042026-05-01 05:08:22.808 AMinfoStudy Ceiling 9 rssi is -52dBm
dev:28032026-05-01 05:08:22.681 AMinfoStudy Ceiling 8 rssi is -65dBm
dev:28082026-05-01 05:08:22.679 AMinfoStudy Ceiling 2 rssi is -64dBm
dev:27962026-05-01 05:08:22.669 AMinfoReading rssi is -74dBm
dev:28052026-05-01 05:08:22.669 AMinfoLiving Room Floor Lamp rssi is -29dBm
dev:28082026-05-01 05:06:22.966 AMinfoStudy Ceiling 2 rssi is -65dBm
dev:28052026-05-01 05:06:22.862 AMinfoLiving Room Floor Lamp rssi is -30dBm
dev:28032026-05-01 05:06:22.770 AMinfoStudy Ceiling 8 rssi is -66dBm
dev:28022026-05-01 05:06:22.769 AMinfoStudy Ceiling 3 rssi is -68dBm
dev:27992026-05-01 05:06:22.759 AMinfoStudy Ceiling 1 rssi is -67dBm
dev:28012026-05-01 05:06:22.698 AMinfoStudy Ceiling 6 rssi is -45dBm
dev:28042026-05-01 05:06:22.697 AMinfoStudy Ceiling 9 rssi is -53dBm
dev:28062026-05-01 05:06:22.642 AMinfoFamily Room Torch rssi is -30dBm
dev:27992026-05-01 05:04:22.763 AMinfoStudy Ceiling 1 rssi is -66dBm
dev:27962026-05-01 05:04:22.751 AMinfoReading rssi is -71dBm
dev:28052026-05-01 05:04:22.750 AMinfoLiving Room Floor Lamp rssi is -29dBm
dev:28032026-05-01 05:04:22.749 AMinfoStudy Ceiling 8 rssi is -65dBm
dev:28082026-05-01 05:04:22.747 AMinfoStudy Ceiling 2 rssi is -67dBm
dev:28022026-05-01 05:04:22.744 AMinfoStudy Ceiling 3 rssi is -67dBm
dev:28042026-05-01 05:04:22.698 AMinfoStudy Ceiling 9 rssi is -51dBm
dev:28052026-05-01 05:02:22.831 AMinfoLiving Room Floor Lamp rssi is -30dBm
dev:28042026-05-01 05:02:22.779 AMinfoStudy Ceiling 9 rssi is -52dBm
dev:28082026-05-01 05:02:22.749 AMinfoStudy Ceiling 2 rssi is -65dBm
dev:27962026-05-01 05:02:22.743 AMinfoReading rssi is -70dBm
dev:28032026-05-01 05:02:22.742 AMinfoStudy Ceiling 8 rssi is -64dBm
dev:27992026-05-01 05:02:22.731 AMinfoStudy Ceiling 1 rssi is -67dBm
dev:28002026-05-01 05:02:22.672 AMinfoStudy Ceiling 4 rssi is -47dBm
dev:28012026-05-01 05:02:22.665 AMinfoStudy Ceiling 6 rssi is -46dBm
dev:27972026-05-01 05:02:22.663 AMinfoStudy Ceiling 5 rssi is -51dBm
dev:27992026-05-01 05:00:22.818 AMinfoStudy Ceiling 1 rssi is -66dBm
dev:28022026-05-01 05:00:22.816 AMinfoStudy Ceiling 3 rssi is -68dBm
dev:27962026-05-01 05:00:22.816 AMinfoReading rssi is -71dBm
dev:28012026-05-01 05:00:22.758 AMinfoStudy Ceiling 6 rssi is -45dBm
dev:28002026-05-01 05:00:22.764 AMinfoStudy Ceiling 4 rssi is -46dBm
dev:28062026-05-01 05:00:22.640 AMinfoFamily Room Torch rssi is -31dBm
dev:28012026-05-01 04:58:22.744 AMinfoStudy Ceiling 6 rssi is -44dBm
dev:27982026-05-01 04:58:22.741 AMinfoStudy Ceiling 7 rssi is -54dBm
dev:27972026-05-01 04:58:22.740 AMinfoStudy Ceiling 5 rssi is -53dBm
dev:28002026-05-01 04:58:22.740 AMinfoStudy Ceiling 4 rssi is -47dBm
dev:28052026-05-01 04:58:22.703 AMinfoLiving Room Floor Lamp rssi is -28dBm
dev:27962026-05-01 04:58:22.703 AMinfoReading rssi is -70dBm
dev:28062026-05-01 04:58:22.639 AMinfoFamily Room Torch rssi is -33dBm
dev:28052026-05-01 04:56:22.898 AMinfoLiving Room Floor Lamp rssi is -29dBm
dev:28082026-05-01 04:56:22.892 AMinfoStudy Ceiling 2 rssi is -66dBm
dev:28022026-05-01 04:56:22.861 AMinfoStudy Ceiling 3 rssi is -67dBm
dev:28002026-05-01 04:56:22.701 AMinfoStudy Ceiling 4 rssi is -46dBm
dev:28042026-05-01 04:56:22.706 AMinfoStudy Ceiling 9 rssi is -53dBm
dev:27982026-05-01 04:54:22.810 AMinfoStudy Ceiling 7 rssi is -53dBm
dev:28002026-05-01 04:54:22.808 AMinfoStudy Ceiling 4 rssi is -47dBm
dev:28082026-05-01 04:54:22.778 AMinfoStudy Ceiling 2 rssi is -67dBm
dev:28022026-05-01 04:54:22.779 AMinfoStudy Ceiling 3 rssi is -68dBm
dev:27992026-05-01 04:54:22.776 AMinfoStudy Ceiling 1 rssi is -67dBm
dev:27962026-05-01 04:54:22.774 AMinfoReading rssi is -71dBm
dev:28032026-05-01 04:54:22.771 AMinfoStudy Ceiling 8 rssi is -65dBm
dev:27972026-05-01 04:54:22.704 AMinfoStudy Ceiling 5 rssi is -51dBm
dev:27992026-05-01 04:52:22.768 AMinfoStudy Ceiling 1 rssi is -66dBm
dev:28032026-05-01 04:52:22.758 AMinfoStudy Ceiling 8 rssi is -64dBm
dev:28052026-05-01 04:52:22.756 AMinfoLiving Room Floor Lamp rssi is -30dBm
dev:27962026-05-01 04:52:22.755 AMinfoReading rssi is -72dBm
dev:27972026-05-01 04:52:22.707 AMinfoStudy Ceiling 5 rssi is -52dBm
dev:28062026-05-01 04:52:22.639 AMinfoFamily Room Torch rssi is -32dBm
dev:28082026-05-01 04:50:22.946 AMinfoStudy Ceiling 2 rssi is -65dBm
dev:27962026-05-01 04:50:22.753 AMinfoReading rssi is -70dBm
dev:28032026-05-01 04:50:22.749 AMinfoStudy Ceiling 8 rssi is -65dBm
dev:27972026-05-01 04:50:22.697 AMinfoStudy Ceiling 5 rssi is -53dBm
dev:27982026-05-01 04:50:22.688 AMinfoStudy Ceiling 7 rssi is -54dBm
dev:28012026-05-01 04:50:22.688 AMinfoStudy Ceiling 6 rssi is -45dBm
dev:28002026-05-01 04:50:22.677 AMinfoStudy Ceiling 4 rssi is -46dBm
dev:28022026-05-01 04:48:22.838 AMinfoStudy Ceiling 3 rssi is -67dBm
dev:27992026-05-01 04:48:22.835 AMinfoStudy Ceiling 1 rssi is -67dBm
dev:28052026-05-01 04:48:22.834 AMinfoLiving Room Floor Lamp rssi is -29dBm
dev:28032026-05-01 04:48:22.832 AMinfoStudy Ceiling 8 rssi is -66dBm
dev:27982026-05-01 04:48:22.781 AMinfoStudy Ceiling 7 rssi is -53dBm
dev:27972026-05-01 04:48:22.765 AMinfoStudy Ceiling 5 rssi is -51dBm
dev:28082026-05-01 04:46:22.821 AMinfoStudy Ceiling 2 rssi is -66dBm
dev:28012026-05-01 04:46:22.774 AMinfoStudy Ceiling 6 rssi is -44dBm
dev:28002026-05-01 04:44:22.856 AMinfoStudy Ceiling 4 rssi is -47dBm
dev:27972026-05-01 04:44:22.862 AMinfoStudy Ceiling 5 rssi is -53dBm
dev:28012026-05-01 04:44:22.862 AMinfoStudy Ceiling 6 rssi is -46dBm
dev:28032026-05-01 04:44:22.711 AMinfoStudy Ceiling 8 rssi is -67dBm
dev:28022026-05-01 04:44:22.711 AMinfoStudy Ceiling 3 rssi is -66dBm
dev:28082026-05-01 04:44:22.707 AMinfoStudy Ceiling 2 rssi is -67dBm
dev:27962026-05-01 04:44:22.705 AMinfoReading rssi is -71dBm
dev:28042026-05-01 04:42:22.930 AMinfoStudy Ceiling 9 rssi is -52dBm
dev:27972026-05-01 04:42:22.835 AMinfoStudy Ceiling 5 rssi is -51dBm
dev:28002026-05-01 04:42:22.827 AMinfoStudy Ceiling 4 rssi is -46dBm
dev:28082026-05-01 04:42:22.786 AMinfoStudy Ceiling 2 rssi is -66dBm
dev:28052026-05-01 04:42:22.786 AMinfoLiving Room Floor Lamp rssi is -30dBm
dev:28022026-05-01 04:42:22.686 AMinfoStudy Ceiling 3 rssi is -68dBm
dev:28062026-05-01 04:42:22.641 AMinfoFamily Room Torch rssi is -31dBm
dev:28042026-05-01 04:40:22.815 AMinfoStudy Ceiling 9 rssi is -53dBm
dev:28002026-05-01 04:40:22.814 AMinfoStudy Ceiling 4 rssi is -47dBm
dev:28012026-05-01 04:40:22.814 AMinfoStudy Ceiling 6 rssi is -44dBm
dev:28032026-05-01 04:40:22.782 AMinfoStudy Ceiling 8 rssi is -65dBm
dev:28082026-05-01 04:40:22.674 AMinfoStudy Ceiling 2 rssi is -65dBm
dev:28062026-05-01 04:40:22.643 AMinfoFamily Room Torch rssi is -35dBm
dev:28002026-05-01 04:38:22.818 AMinfoStudy Ceiling 4 rssi is -46dBm
dev:28042026-05-01 04:38:22.811 AMinfoStudy Ceiling 9 rssi is -52dBm
dev:27982026-05-01 04:38:22.810 AMinfoStudy Ceiling 7 rssi is -54dBm
dev:28012026-05-01 04:38:22.799 AMinfoStudy Ceiling 6 rssi is -46dBm
dev:28022026-05-01 04:38:22.756 AMinfoStudy Ceiling 3 rssi is -67dBm
dev:28052026-05-01 04:38:22.692 AMinfoLiving Room Floor Lamp rssi is -29dBm
dev:28032026-05-01 04:38:22.689 AMinfoStudy Ceiling 8 rssi is -67dBm
dev:28062026-05-01 04:38:22.689 AMinfoFamily Room Torch rssi is -31dBm
dev:28072026-05-01 04:38:22.639 AMinfoStudy Torch Light rssi is -39dBm
dev:28052026-05-01 04:36:22.950 AMinfoLiving Room Floor Lamp rssi is -31dBm
dev:27962026-05-01 04:36:22.853 AMinfoReading rssi is -70dBm
dev:28032026-05-01 04:36:22.848 AMinfoStudy Ceiling 8 rssi is -64dBm
dev:28022026-05-01 04:36:22.845 AMinfoStudy Ceiling 3 rssi is -68dBm
dev:28042026-05-01 04:36:22.685 AMinfoStudy Ceiling 9 rssi is -51dBm
dev:28012026-05-01 04:36:22.684 AMinfoStudy Ceiling 6 rssi is -44dBm
dev:28002026-05-01 04:36:22.684 AMinfoStudy Ceiling 4 rssi is -48dBm
dev:28062026-05-01 04:36:22.639 AMinfoFamily Room Torch rssi is -34dBm
dev:28012026-05-01 04:34:22.773 AMinfoStudy Ceiling 6 rssi is -45dBm
dev:28042026-05-01 04:34:22.770 AMinfoStudy Ceiling 9 rssi is -52dBm
dev:27972026-05-01 04:34:22.768 AMinfoStudy Ceiling 5 rssi is -53dBm
dev:28022026-05-01 04:34:22.744 AMinfoStudy Ceiling 3 rssi is -67dBm
dev:28082026-05-01 04:34:22.739 AMinfoStudy Ceiling 2 rssi is -67dBm
dev:27962026-05-01 04:34:22.734 AMinfoReading rssi is -71dBm
dev:28052026-05-01 04:34:22.730 AMinfoLiving Room Floor Lamp rssi is -30dBm
dev:28032026-05-01 04:34:22.730 AMinfoStudy Ceiling 8 rssi is -67dBm
dev:28062026-05-01 04:34:22.646 AMinfoFamily Room Torch rssi is -29dBm
dev:28082026-05-01 04:32:22.759 AMinfoStudy Ceiling 2 rssi is -65dBm
dev:28052026-05-01 04:32:22.754 AMinfoLiving Room Floor Lamp rssi is -31dBm
dev:28022026-05-01 04:32:22.752 AMinfoStudy Ceiling 3 rssi is -68dBm
dev:27982026-05-01 04:32:22.659 AMinfoStudy Ceiling 7 rssi is -55dBm
dev:28012026-05-01 04:32:22.659 AMinfoStudy Ceiling 6 rssi is -46dBm
dev:28002026-05-01 04:32:22.656 AMinfoStudy Ceiling 4 rssi is -46dBm
dev:27972026-05-01 04:32:22.656 AMinfoStudy Ceiling 5 rssi is -52dBm
dev:28042026-05-01 04:30:22.873 AMinfoStudy Ceiling 9 rssi is -51dBm
dev:27982026-05-01 04:30:22.870 AMinfoStudy Ceiling 7 rssi is -54dBm
dev:28032026-05-01 04:30:22.868 AMinfoStudy Ceiling 8 rssi is -65dBm
dev:28012026-05-01 04:30:22.863 AMinfoStudy Ceiling 6 rssi is -44dBm
dev:27962026-05-01 04:30:22.859 AMinfoReading rssi is -70dBm
dev:28082026-05-01 04:30:22.805 AMinfoStudy Ceiling 2 rssi is -67dBm
dev:28072026-05-01 04:30:22.639 AMinfoStudy Torch Light rssi is -40dBm
dev:28062026-05-01 04:30:22.639 AMinfoFamily Room Torch rssi is -31dBm
dev:28052026-05-01 04:28:22.793 AMinfoLiving Room Floor Lamp rssi is -29dBm
dev:28032026-05-01 04:28:22.791 AMinfoStudy Ceiling 8 rssi is -67dBm
dev:28082026-05-01 04:28:22.785 AMinfoStudy Ceiling 2 rssi is -65dBm
dev:28042026-05-01 04:28:22.730 AMinfoStudy Ceiling 9 rssi is -53dBm
dev:28012026-05-01 04:28:22.730 AMinfoStudy Ceiling 6 rssi is -45dBm
dev:27982026-05-01 04:28:22.728 AMinfoStudy Ceiling 7 rssi is -55dBm
dev:28002026-05-01 04:28:22.728 AMinfoStudy Ceiling 4 rssi is -47dBm
dev:28062026-05-01 04:28:22.644 AMinfoFamily Room Torch rssi is -32dBm
dev:28072026-05-01 04:28:22.641 AMinfoStudy Torch Light rssi is -39dBm
dev:27992026-05-01 04:26:22.850 AMinfoStudy Ceiling 1 rssi is -68dBm
dev:28032026-05-01 04:26:22.850 AMinfoStudy Ceiling 8 rssi is -65dBm
dev:28052026-05-01 04:26:22.844 AMinfoLiving Room Floor Lamp rssi is -30dBm
dev:28082026-05-01 04:26:22.843 AMinfoStudy Ceiling 2 rssi is -66dBm
dev:28022026-05-01 04:26:22.827 AMinfoStudy Ceiling 3 rssi is -67dBm
dev:28002026-05-01 04:26:22.798 AMinfoStudy Ceiling 4 rssi is -48dBm
dev:27972026-05-01 04:26:22.793 AMinfoStudy Ceiling 5 rssi is -53dBm
dev:28012026-05-01 04:26:22.790 AMinfoStudy Ceiling 6 rssi is -44dBm
dev:28072026-05-01 04:26:22.685 AMinfoStudy Torch Light rssi is -40dBm
dev:28032026-05-01 04:24:22.759 AMinfoStudy Ceiling 8 rssi is -64dBm
dev:27972026-05-01 04:24:22.714 AMinfoStudy Ceiling 5 rssi is -52dBm
dev:27992026-05-01 04:24:22.711 AMinfoStudy Ceiling 1 rssi is -67dBm
dev:27982026-05-01 04:24:22.708 AMinfoStudy Ceiling 7 rssi is -54dBm
dev:28052026-05-01 04:24:22.703 AMinfoLiving Room Floor Lamp rssi is -31dBm
dev:28082026-05-01 04:24:22.702 AMinfoStudy Ceiling 2 rssi is -65dBm
dev:27962026-05-01 04:24:22.658 AMinfoReading rssi is -71dBm
dev:28032026-05-01 04:22:22.953 AMinfoStudy Ceiling 8 rssi is -67dBm
dev:28052026-05-01 04:22:22.745 AMinfoLiving Room Floor Lamp rssi is -30dBm
dev:27982026-05-01 04:22:22.726 AMinfoStudy Ceiling 7 rssi is -55dBm
dev:28012026-05-01 04:22:22.720 AMinfoStudy Ceiling 6 rssi is -45dBm
dev:27972026-05-01 04:22:22.681 AMinfoStudy Ceiling 5 rssi is -53dBm
dev:28082026-05-01 04:20:22.748 AMinfoStudy Ceiling 2 rssi is -67dBm
dev:28022026-05-01 04:20:22.744 AMinfoStudy Ceiling 3 rssi is -68dBm
dev:28032026-05-01 04:20:22.742 AMinfoStudy Ceiling 8 rssi is -63dBm
dev:27972026-05-01 04:20:22.682 AMinfoStudy Ceiling 5 rssi is -51dBm
dev:27982026-05-01 04:20:22.679 AMinfoStudy Ceiling 7 rssi is -54dBm
dev:28032026-05-01 04:18:22.828 AMinfoStudy Ceiling 8 rssi is -68dBm
dev:27962026-05-01 04:18:22.823 AMinfoReading rssi is -70dBm
dev:28002026-05-01 04:18:22.665 AMinfoStudy Ceiling 4 rssi is -47dBm
dev:27972026-05-01 04:18:22.658 AMinfoStudy Ceiling 5 rssi is -54dBm
dev:27982026-05-01 04:18:22.649 AMinfoStudy Ceiling 7 rssi is -53dBm
dev:28072026-05-01 04:18:22.638 AMinfoStudy Torch Light rssi is -39dBm
dev:27962026-05-01 04:17:04.203 AMinfoReading rssi is -71dBm
dev:27992026-05-01 04:17:04.196 AMinfoStudy Ceiling 1 rssi is -68dBm
dev:28052026-05-01 04:17:04.192 AMinfoLiving Room Floor Lamp rssi is -31dBm
dev:28022026-05-01 04:17:04.187 AMinfoStudy Ceiling 3 rssi is -66dBm
dev:28002026-05-01 04:17:04.167 AMinfoStudy Ceiling 4 rssi is -46dBm
dev:28042026-05-01 04:17:04.155 AMinfoStudy Ceiling 9 rssi is -52dBm
dev:27972026-05-01 04:17:04.161 AMinfoStudy Ceiling 5 rssi is -51dBm
dev:28012026-05-01 04:17:04.158 AMinfoStudy Ceiling 6 rssi is -44dBm
dev:28072026-05-01 04:17:04.157 AMinfoStudy Torch Light rssi is -38dBm
dev:28032026-05-01 04:16:22.907 AMinfoStudy Ceiling 8 rssi is -67dBm
dev:28082026-05-01 04:16:22.817 AMinfoStudy Ceiling 2 rssi is -68dBm
dev:27992026-05-01 04:16:22.809 AMinfoStudy Ceiling 1 rssi is -67dBm
dev:28042026-05-01 04:16:22.758 AMinfoStudy Ceiling 9 rssi is -51dBm
dev:28002026-05-01 04:16:22.754 AMinfoStudy Ceiling 4 rssi is -47dBm
dev:28012026-05-01 04:16:22.754 AMinfoStudy Ceiling 6 rssi is -45dBm
dev:28052026-05-01 04:16:22.703 AMinfoLiving Room Floor Lamp rssi is -29dBm
dev:27992026-05-01 04:14:22.800 AMinfoStudy Ceiling 1 rssi is -70dBm
dev:28052026-05-01 04:14:22.792 AMinfoLiving Room Floor Lamp rssi is -28dBm
dev:27962026-05-01 04:14:22.792 AMinfoReading rssi is -70dBm
dev:28002026-05-01 04:12:22.711 AMinfoStudy Ceiling 4 rssi is -46dBm
dev:27972026-05-01 04:12:22.711 AMinfoStudy Ceiling 5 rssi is -53dBm
dev:28012026-05-01 04:12:22.711 AMinfoStudy Ceiling 6 rssi is -44dBm
dev:28052026-05-01 04:12:22.694 AMinfoLiving Room Floor Lamp rssi is -29dBm
dev:27992026-05-01 04:12:22.691 AMinfoStudy Ceiling 1 rssi is -68dBm
dev:28082026-05-01 04:12:22.686 AMinfoStudy Ceiling 2 rssi is -67dBm
dev:28032026-05-01 04:12:22.677 AMinfoStudy Ceiling 8 rssi is -68dBm
dev:28062026-05-01 04:12:22.639 AMinfoFamily Room Torch rssi is -31dBm
dev:28002026-05-01 04:10:22.695 AMinfoStudy Ceiling 4 rssi is -47dBm
dev:28012026-05-01 04:10:22.694 AMinfoStudy Ceiling 6 rssi is -45dBm
dev:27992026-05-01 04:10:22.674 AMinfoStudy Ceiling 1 rssi is -66dBm
dev:28082026-05-01 04:10:22.670 AMinfoStudy Ceiling 2 rssi is -66dBm
dev:28032026-05-01 04:10:22.667 AMinfoStudy Ceiling 8 rssi is -67dBm
dev:27962026-05-01 04:10:22.666 AMinfoReading rssi is -71dBm
dev:27982026-05-01 04:08:22.790 AMinfoStudy Ceiling 7 rssi is -54dBm
dev:28002026-05-01 04:08:22.780 AMinfoStudy Ceiling 4 rssi is -46dBm
dev:28052026-05-01 04:08:22.765 AMinfoLiving Room Floor Lamp rssi is -30dBm
dev:27962026-05-01 04:08:22.764 AMinfoReading rssi is -70dBm
dev:28022026-05-01 04:08:22.752 AMinfoStudy Ceiling 3 rssi is -67dBm
dev:28082026-05-01 04:08:22.751 AMinfoStudy Ceiling 2 rssi is -67dBm
dev:28032026-05-01 04:08:22.747 AMinfoStudy Ceiling 8 rssi is -68dBm
dev:27992026-05-01 04:08:22.742 AMinfoStudy Ceiling 1 rssi is -68dBm
dev:28062026-05-01 04:08:22.643 AMinfoFamily Room Torch rssi is -29dBm
dev:28082026-05-01 04:06:22.753 AMinfoStudy Ceiling 2 rssi is -66dBm
dev:28022026-05-01 04:06:22.753 AMinfoStudy Ceiling 3 rssi is -65dBm
dev:27962026-05-01 04:06:22.752 AMinfoReading rssi is -71dBm
dev:28052026-05-01 04:06:22.749 AMinfoLiving Room Floor Lamp rssi is -29dBm
dev:27992026-05-01 04:06:22.739 AMinfoStudy Ceiling 1 rssi is -66dBm
dev:27972026-05-01 04:06:22.734 AMinfoStudy Ceiling 5 rssi is -51dBm
dev:27982026-05-01 04:06:22.729 AMinfoStudy Ceiling 7 rssi is -53dBm
dev:28012026-05-01 04:06:22.723 AMinfoStudy Ceiling 6 rssi is -44dBm
dev:28002026-05-01 04:06:22.721 AMinfoStudy Ceiling 4 rssi is -48dBm
dev:28072026-05-01 04:06:22.645 AMinfoStudy Torch Light rssi is -39dBm
dev:28062026-05-01 04:06:22.645 AMinfoFamily Room Torch rssi is -31dBm
dev:28052026-05-01 04:04:22.828 AMinfoLiving Room Floor Lamp rssi is -30dBm
dev:28032026-05-01 04:04:22.820 AMinfoStudy Ceiling 8 rssi is -67dBm
dev:27972026-05-01 04:04:22.796 AMinfoStudy Ceiling 5 rssi is -52dBm
dev:28042026-05-01 04:04:22.796 AMinfoStudy Ceiling 9 rssi is -52dBm
dev:28012026-05-01 04:04:22.795 AMinfoStudy Ceiling 6 rssi is -45dBm
dev:28062026-05-01 04:04:22.651 AMinfoFamily Room Torch rssi is -33dBm
dev:28072026-05-01 04:04:22.642 AMinfoStudy Torch Light rssi is -40dBm
dev:27992026-05-01 04:02:22.906 AMinfoStudy Ceiling 1 rssi is -68dBm
dev:27982026-05-01 04:02:22.851 AMinfoStudy Ceiling 7 rssi is -54dBm
dev:27972026-05-01 04:02:22.846 AMinfoStudy Ceiling 5 rssi is -54dBm
dev:28012026-05-01 04:02:22.844 AMinfoStudy Ceiling 6 rssi is -46dBm
dev:28082026-05-01 04:02:22.817 AMinfoStudy Ceiling 2 rssi is -67dBm
dev:28022026-05-01 04:02:22.809 AMinfoStudy Ceiling 3 rssi is -67dBm
dev:28052026-05-01 04:02:22.807 AMinfoLiving Room Floor Lamp rssi is -32dBm
dev:28042026-05-01 04:02:22.744 AMinfoStudy Ceiling 9 rssi is -51dBm
dev:27972026-05-01 04:00:22.813 AMinfoStudy Ceiling 5 rssi is -53dBm
dev:28042026-05-01 04:00:22.811 AMinfoStudy Ceiling 9 rssi is -52dBm
dev:27982026-05-01 04:00:22.807 AMinfoStudy Ceiling 7 rssi is -55dBm
dev:28012026-05-01 04:00:22.806 AMinfoStudy Ceiling 6 rssi is -44dBm
dev:28002026-05-01 04:00:22.805 AMinfoStudy Ceiling 4 rssi is -47dBm
dev:28082026-05-01 04:00:22.705 AMinfoStudy Ceiling 2 rssi is -66dBm
dev:28022026-05-01 04:00:22.701 AMinfoStudy Ceiling 3 rssi is -66dBm
dev:28052026-05-01 04:00:22.699 AMinfoLiving Room Floor Lamp rssi is -31dBm
dev:27992026-05-01 04:00:22.699 AMinfoStudy Ceiling 1 rssi is -67dBm
dev:27962026-05-01 04:00:22.697 AMinfoReading rssi is -70dBm
dev:28032026-05-01 04:00:22.689 AMinfoStudy Ceiling 8 rssi is -68dBm
dev:28072026-05-01 04:00:22.640 AMinfoStudy Torch Light rssi is -39dBm
dev:27972026-05-01 03:58:22.863 AMinfoStudy Ceiling 5 rssi is -54dBm
dev:28002026-05-01 03:58:22.862 AMinfoStudy Ceiling 4 rssi is -48dBm
dev:28022026-05-01 03:58:22.790 AMinfoStudy Ceiling 3 rssi is -68dBm
dev:27962026-05-01 03:58:22.787 AMinfoReading rssi is -71dBm
dev:28082026-05-01 03:58:22.784 AMinfoStudy Ceiling 2 rssi is -64dBm
dev:28052026-05-01 03:58:22.779 AMinfoLiving Room Floor Lamp rssi is -30dBm
dev:27962026-05-01 03:56:22.771 AMinfoReading rssi is -72dBm
dev:28052026-05-01 03:56:22.757 AMinfoLiving Room Floor Lamp rssi is -29dBm
dev:27992026-05-01 03:56:22.757 AMinfoStudy Ceiling 1 rssi is -68dBm
dev:27972026-05-01 03:56:22.732 AMinfoStudy Ceiling 5 rssi is -53dBm
dev:28012026-05-01 03:56:22.705 AMinfoStudy Ceiling 6 rssi is -45dBm
dev:28022026-05-01 03:56:22.665 AMinfoStudy Ceiling 3 rssi is -67dBm
dev:28062026-05-01 03:56:22.639 AMinfoFamily Room Torch rssi is -31dBm
dev:28072026-05-01 03:56:22.639 AMinfoStudy Torch Light rssi is -40dBm
dev:28042026-05-01 03:54:22.827 AMinfoStudy Ceiling 9 rssi is -53dBm
dev:27972026-05-01 03:54:22.827 AMinfoStudy Ceiling 5 rssi is -54dBm
dev:27992026-05-01 03:54:22.759 AMinfoStudy Ceiling 1 rssi is -67dBm
dev:28032026-05-01 03:54:22.756 AMinfoStudy Ceiling 8 rssi is -67dBm
dev:28052026-05-01 03:54:22.750 AMinfoLiving Room Floor Lamp rssi is -30dBm
dev:28072026-05-01 03:54:22.641 AMinfoStudy Torch Light rssi is -39dBm
dev:27992026-05-01 03:52:22.844 AMinfoStudy Ceiling 1 rssi is -68dBm
dev:27962026-05-01 03:52:22.839 AMinfoReading rssi is -71dBm
dev:28032026-05-01 03:52:22.838 AMinfoStudy Ceiling 8 rssi is -64dBm
dev:28052026-05-01 03:52:22.837 AMinfoLiving Room Floor Lamp rssi is -31dBm
dev:28042026-05-01 03:52:22.765 AMinfoStudy Ceiling 9 rssi is -52dBm
dev:28082026-05-01 03:52:22.732 AMinfoStudy Ceiling 2 rssi is -66dBm
dev:28062026-05-01 03:52:22.637 AMinfoFamily Room Torch rssi is -30dBm
dev:28072026-05-01 03:52:22.637 AMinfoStudy Torch Light rssi is -40dBm
dev:28042026-05-01 03:50:22.855 AMinfoStudy Ceiling 9 rssi is -53dBm
dev:28032026-05-01 03:50:22.823 AMinfoStudy Ceiling 8 rssi is -67dBm
dev:27972026-05-01 03:50:22.760 AMinfoStudy Ceiling 5 rssi is -53dBm
dev:28012026-05-01 03:50:22.754 AMinfoStudy Ceiling 6 rssi is -44dBm
dev:27992026-05-01 03:50:22.733 AMinfoStudy Ceiling 1 rssi is -66dBm
dev:28082026-05-01 03:50:22.726 AMinfoStudy Ceiling 2 rssi is -65dBm
dev:27962026-05-01 03:50:22.725 AMinfoReading rssi is -70dBm
dev:28052026-05-01 03:50:22.717 AMinfoLiving Room Floor Lamp rssi is -29dBm
dev:27982026-05-01 03:50:22.663 AMinfoStudy Ceiling 7 rssi is -54dBm
dev:28072026-05-01 03:50:22.662 AMinfoStudy Torch Light rssi is -39dBm
dev:28042026-05-01 03:48:22.856 AMinfoStudy Ceiling 9 rssi is -52dBm
dev:27972026-05-01 03:48:22.854 AMinfoStudy Ceiling 5 rssi is -54dBm
dev:28002026-05-01 03:48:22.854 AMinfoStudy Ceiling 4 rssi is -47dBm
dev:27982026-05-01 03:48:22.854 AMinfoStudy Ceiling 7 rssi is -55dBm
dev:28012026-05-01 03:48:22.847 AMinfoStudy Ceiling 6 rssi is -46dBm
dev:28082026-05-01 03:48:22.746 AMinfoStudy Ceiling 2 rssi is -64dBm
dev:28022026-05-01 03:48:22.746 AMinfoStudy Ceiling 3 rssi is -68dBm
dev:27992026-05-01 03:48:22.745 AMinfoStudy Ceiling 1 rssi is -70dBm
dev:28072026-05-01 03:48:22.685 AMinfoStudy Torch Light rssi is -41dBm
dev:27962026-05-01 03:46:22.810 AMinfoReading rssi is -71dBm
dev:28032026-05-01 03:46:22.808 AMinfoStudy Ceiling 8 rssi is -66dBm
dev:27992026-05-01 03:46:22.799 AMinfoStudy Ceiling 1 rssi is -69dBm
dev:28082026-05-01 03:46:22.795 AMinfoStudy Ceiling 2 rssi is -63dBm
dev:28052026-05-01 03:46:22.794 AMinfoLiving Room Floor Lamp rssi is -30dBm
dev:28022026-05-01 03:46:22.794 AMinfoStudy Ceiling 3 rssi is -69dBm
dev:28012026-05-01 03:46:22.745 AMinfoStudy Ceiling 6 rssi is -45dBm
dev:28042026-05-01 03:46:22.743 AMinfoStudy Ceiling 9 rssi is -51dBm
dev:28062026-05-01 03:46:22.642 AMinfoFamily Room Torch rssi is -31dBm
dev:28052026-05-01 03:44:22.877 AMinfoLiving Room Floor Lamp rssi is -31dBm
dev:28012026-05-01 03:44:22.836 AMinfoStudy Ceiling 6 rssi is -44dBm
dev:27982026-05-01 03:44:22.829 AMinfoStudy Ceiling 7 rssi is -54dBm
dev:28042026-05-01 03:44:22.818 AMinfoStudy Ceiling 9 rssi is -52dBm
dev:28002026-05-01 03:44:22.818 AMinfoStudy Ceiling 4 rssi is -49dBm
dev:27992026-05-01 03:44:22.777 AMinfoStudy Ceiling 1 rssi is -70dBm
dev:28022026-05-01 03:44:22.775 AMinfoStudy Ceiling 3 rssi is -68dBm
dev:27972026-05-01 03:42:22.713 AMinfoStudy Ceiling 5 rssi is -53dBm
dev:27982026-05-01 03:42:22.712 AMinfoStudy Ceiling 7 rssi is -55dBm
Checking. 13 LIFX bulbs each reporting rssi every two, four or six minutes. Which seems odd too. Mostly every two minutes.
Currently running 2.5.0.135 and still getting tons of rssi statistics. Don't know if your "toning" made it into production yet. If so, no bueno. I've gotten 500 of them in the past two hours. Kind of overwhelming my logs... Please advise if there's anything I can do to settle this down. I can't believe everyone with LIFX isn't complaining.
I'm also seeing this, but don't look at my logs that often. - But I would like it "toned down" - I just have lots of other higher priority stuff to complain about..
Same here lots of RSSI messages from my LIFX bulb since I updated to .135 yesterday.
It was supposed to have dropped.. I'll just remove it from the next build..
The polling of RSSI was for a future integration update to track up/down status for these bulbs .. But there is no need for it to show up in logs..
A very needed addition, and glad to see it has a future! - It's like working with ZW when where in a ZW+ world...
I guess I'm a whiner. But 500 log entries every two hours is kind of a lot. I'm mean a lot a lot.
For those of us with OCD, can you drop a line in the release notes when you release the build that fixes this? please and thank you
