Since 2.0.2, I finally got Life360 working (couldn't get it working at all prior to 2.0.2).
However, I notice sometimes my devices don't change states. When I look in the logs I see an error: setWebhook Error:[errorMessage:Not Found,url:/v3/circles/webhook.json, status:404]
When I check on the Life360 Connector app config, it shows login OK, but no circle, location, or people selected. So I configure it again, hit done, and it starts working.
I just noticed again that devices were not changing presence state. Looked at logs, and see my config was wiped out again. I re-configured the circle, location, and people and it is working again.
Why does it keep getting wiped out?
I do have a RM rule to toggle the Refresh Life 360 button every 5 minutes, maybe that has something to do with it. But I don't think it should wipe out my config even with that?
If I don't periodically refresh, then Life 360 doesn't reliably update - sometimes it will update devices, sometimes it wont. Status is always correct after a manual refresh though.
But if I setup an RM to periodically refresh every 5 minutes, then it seems to wipe out the Life 360 config after a while.
I will probably try that tonight. The problem certainly does not appear to be on the Life 360 side - I setup notifications in Life 360 for every user when arriving home. I get those notifications 100% of the time, but the devices don't update in HE predictably. Sometimes they do, sometimes they don't.
To be fair, it was the exact same in ST, too, which is why I had a WebCore piston to force refresh Life 360 every 5 minutes. That made it work reliably.
