I hope your wiring project went well. Did you ever get around to building a driver for the 131S?
Crap, has it really been three months?? Looks like I am a good procrastinator. I didn’t forget, it just hasn’t bubbled up to the top of the list. I check it out by the end of this week. And yes the wiring project was straight forward, thanks for asking.
For Christmas I got a new iotawatt system. That’s still on the list as well. Geesh.
Thanks Nick, I'll see what I can come up with.
Ok, i finally spent some time on this.
I should say that building a driver is probably outside my skill set, but i have been playing.
I will continue tomorrow.
Played with it twice more this week. I didn’t get past where I was.
At what step are you seeing this? Do you have your code on GitHub? If so, I can take a look.
I suggest using Postman to manually explore the API -- that's what I've been doing. The login and listing of devices should be the same, anyway, it's just when you access the device itself that the code should be deviating.
I modified your parent driver to include my model. Then I created a new child driver based of your 400 model. The I created a virtual device using the parent driver, put in my credential, get an account ID and token and hit resync.
It properly selects the correct child driver but I have a data mismatch (off course) and I don’t see any feedback to help me resolve this. I am not a SW guy so I am not even going to attempt to use postman (I did google it) to debug a cloud API. Definitely above my intelligence level.
I appreciate your offer of help though.
Thanks for building this code! Very useful!
My 600S is recognized as "LAP-C601S-WUS" - from there I was able to modify your code so as to have it work with my 600S. Also, for some reason, I had to add a "max" speed parameter corresponding to level 4, in the device driver.
I would be willing to donate to have drivers for the 131s
Hi, any chance you would be willing to share your modified code for the 600S with me. Thanks.
Sure! There it is. It's messy, though, had little time to implement it, but works.
MIT License
Copyright (c) Niklas Gustafsson
Permission is hereby granted, free of charge, to any person obtaining a copy
of this software and associated documentation files (the "Software"), to deal
in the Software without restriction, including without limitation the rights
to use, copy, modify, merge, publish, distribute, sublicense, and/or sell
copies of the Software, and to permit persons to whom the Software is
furnished to do so, subject to the following conditions:
The above copyright notice and this permission notice shall be included in all
copies or substantial portions of the Software.
THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR
IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY,
FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL THE
AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER
LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING FROM,
OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN THE
SOFTWARE.
// History:
// 2021-10-22: v1.0 Support for Levoit Air Purifier Core 200S / 400S
metadata {
definition(
name: "Levoit Core400S & 600S Air Purifier",
namespace: "NiklasGustafsson",
author: "Niklas Gustafsson and elfege (contributor)",
description: "Supports controlling the Levoit 400S air purifier",
category: "My Apps",
iconUrl: "https://s3.amazonaws.com/smartapp-icons/Convenience/Cat-Convenience.png",
iconX2Url: "https://s3.amazonaws.com/smartapp-icons/Convenience/Cat-Convenience@2x.png",
iconX3Url: "https://s3.amazonaws.com/smartapp-icons/Convenience/Cat-Convenience@2x.png",
documentationLink: "https://github.com/dcmeglio/hubitat-bond/blob/master/README.md")
capability "Switch"
capability "FanControl"
capability "Actuator"
capability "SwitchLevel"
attribute "filter", "number"; // Filter status (0-100%)
attribute "mode", "string"; // Purifier mode
attribute "aqi", "number"; // AQI (0-500)
attribute "aqiDanger", "string"; // AQI danger level
attribute "aqiColor", "string"; // AQI HTML color
attribute "info", "string"; // HTML
command "setDisplay", [[name:"Display*", type: "ENUM", description: "Display", constraints: ["on", "off"] ] ]
command "setSpeed", [[name:"Speed*", type: "ENUM", description: "Speed", constraints: ["off", "sleep", "auto", "low", "medium", "high", "max"] ] ]
command "setMode", [[name:"Mode*", type: "ENUM", description: "Mode", constraints: ["manual", "sleep", "auto"] ] ]
command "toggle"
preferences {
input("debugOutput", "bool", title: "Enable debug logging?", defaultValue: false, required: false)
def installed() {
logDebug "Installed with settings: ${settings}"
updated();
def updated() {
logDebug "Updated with settings: ${settings}"
state.clear()
unschedule()
initialize()
runIn(3, update)
// Turn off debug log in 30 minutes
if (settings?.debugOutput) runIn(1800, logDebugOff);
def parse(String description) // no parse in virtual device
log.trace "Msg: Description is $description"
def uninstalled() {
logDebug "Uninstalled app"
def initialize() {
logDebug "initializing"
def on() {
logDebug "on()"
handlePower(true)
handleEvent("switch", "on")
if (state.speed != null) {
setSpeed(state.speed)
else {
setSpeed("low")
if (state.mode != null) {
setMode(state.mode)
else {
update()
def off() {
logDebug "off()"
handlePower(false)
handleEvent("switch", "off")
handleEvent("speed", "off")
def toggle() {
logDebug "toggle()"
if (device.currentValue("switch") == "on")
off()
else
on()
def cycleSpeed() {
logDebug "cycleSpeed()"
def speed = (state.speed == "low") ? "medium" : ( (state.speed == "medium") ? "high" : "low")
if (state.switch == "off")
on()
setSpeed(speed)
def setLevel(value)
logDebug "setLevel $value"
def speed = 0
setMode("manual") // always manual if setLevel() cmd was called
if(value < 25) speed = 1
if(value >= 25 && value < 50) speed = 2
if(value >= 50 && value < 75) speed = 3
if(value >= 75) speed = 4
sendEvent(name: "level", value: value)
setSpeed(speed)
def setSpeed(speed) {
logDebug "setSpeed(${speed})"
if (speed == "off") {
off()
else if (speed == "auto") {
setMode(speed)
state.speed = speed
handleEvent("speed", speed)
else if (speed == "sleep") {
setMode(speed)
handleEvent("speed", "on")
else if (state.mode == "manual") {
handleSpeed(speed)
state.speed = speed
else if (state.mode == "sleep") {
setMode("manual")
handleSpeed(speed)
state.speed = speed
device.sendEvent(name: "speed", value: speed)
def setMode(mode) {
logDebug "setMode(${mode})"
handleMode(mode)
state.mode = mode
handleEvent("mode", mode)
switch(mode)
case "manual":
handleEvent("speed", state.speed)
break;
case "auto":
handleEvent("speed", "auto")
break;
case "sleep":
break;
def setDisplay(displayOn) {
logDebug "setDisplay(${displayOn})"
handleDisplayOn(displayOn)
def mapSpeedToInteger(speed) {
switch(speed)
case "1":
return 1
case "low":
return 1
case "2":
return 2
case "medium":
return 2
case "3":
return 3
case "high":
return 3
case "4":
return 4
case "max":
return 4
return (speed == "low") ? 1 : ( (speed == "medium") ? 2 : 3)
def mapIntegerStringToSpeed(speed) {
return (speed == "1") ? "low" : ( (speed == "2") ? "medium" : "high")
def mapIntegerToSpeed(speed) {
return (speed == 1) ? "low" : ( (speed == 2) ? "medium" : "high")
def logDebug(msg) {
if (settings?.debugOutput) {
log.debug msg
def logError(msg) {
log.error msg
void logDebugOff() {
// runIn() callback to disable "Debug" logging after 30 minutes
// Cannot be private
if (settings?.debugOutput) device.updateSetting("debugOutput", [type: "bool", value: false]);
def handlePower(on) {
def result = false
parent.sendBypassRequest(device, [
data: [ enabled: on, id: 0 ],
"method": "setSwitch",
"source": "APP" ]) { resp ->
if (checkHttpResponse("handleOn", resp))
def operation = on ? "ON" : "OFF"
logDebug "turned ${operation}()"
result = true
return result
def handleSpeed(speed) {
def result = false
data: [ level: mapSpeedToInteger(speed), id: 0, type: "wind" ],
"method": "setLevel",
"source": "APP"
]) { resp ->
if (checkHttpResponse("handleSpeed", resp))
logDebug "Set speed"
result = true
return result
def handleMode(mode) {
def result = false
data: [ "mode": mode ],
"method": "setPurifierMode",
"source": "APP"
]) { resp ->
if (checkHttpResponse("handleMode", resp))
logDebug "Set mode"
result = true
return result
def update() {
logDebug "update()"
def result = null
"method": "getPurifierStatus",
"source": "APP"
]) { resp ->
if (checkHttpResponse("update", resp))
def status = resp.data.result
result = update(status, null)
return result
def update(status, nightLight){
logDebug "update(status, nightLight)"
logDebug status
state.speed = mapIntegerToSpeed(status.result.level)
state.mode = status.result.mode
handleEvent("switch", status.result.enabled ? "on" : "off")
handleEvent("mode", status.result.mode)
handleEvent("filter", status.result.filter_life)
switch(state.mode)
case "manual":
handleEvent("speed", mapIntegerToSpeed(status.result.level))
break;
case "auto":
break;
case "sleep":
break;
updateAQIandFilter(status.result.air_quality_value.toString(),status.result.filter_life)
private void handleEvent(name, val){
logDebug "handleEvent(${name}, ${val})"
device.sendEvent(name: name, value: val)
private void updateAQIandFilter(String val, filter) {
logDebug "updateAQI(${val})"
// Conversions based on https://en.wikipedia.org/wiki/Air_quality_index
BigDecimal pm = val.toBigDecimal();
BigDecimal aqi;
if (state.prevPM == null || state.prevPM != pm || state.prevFilter == null || state.prevFilter != filter) {
state.prevPM = pm;
state.prevFilter = filter;
if (pm < 12.1) aqi = convertRange(pm, 0.0, 12.0, 0, 50);
else if (pm < 35.5) aqi = convertRange(pm, 12.1, 35.4, 51, 100);
else if (pm < 55.5) aqi = convertRange(pm, 35.5, 55.4, 101, 150);
else if (pm < 150.5) aqi = convertRange(pm, 55.5, 150.4, 151, 200);
else if (pm < 250.5) aqi = convertRange(pm, 150.5, 250.4, 201, 300);
else if (pm < 350.5) aqi = convertRange(pm, 250.5, 350.4, 301, 400);
else aqi = convertRange(pm, 350.5, 500.4, 401, 500);
handleEvent("AQI", aqi);
String danger;
String color;
if (aqi < 51) { danger = "Good"; color = "7e0023"; }
else if (aqi < 101) { danger = "Moderate"; color = "fff300"; }
else if (aqi < 151) { danger = "Unhealthy for Sensitive Groups"; color = "f18b00"; }
else if (aqi < 201) { danger = "Unhealthy"; color = "e53210"; }
else if (aqi < 301) { danger = "Very Unhealthy"; color = "b567a4"; }
else if (aqi < 401) { danger = "Hazardous"; color = "7e0023"; }
else { danger = "Hazardous"; color = "7e0023"; }
handleEvent("aqiColor", color)
handleEvent("aqiDanger", danger)
def html = "AQI: ${aqi}<br>PM2.5: ${pm} µg/m³<br>Filter: ${filter}%"
handleEvent("info", html)
private BigDecimal convertRange(BigDecimal val, BigDecimal inMin, BigDecimal inMax, BigDecimal outMin, BigDecimal outMax, Boolean returnInt = true) {
// Let make sure ranges are correct
assert (inMin <= inMax);
assert (outMin <= outMax);
// Restrain input value
if (val < inMin) val = inMin;
else if (val > inMax) val = inMax;
val = ((val - inMin) * (outMax - outMin)) / (inMax - inMin) + outMin;
if (returnInt) {
// If integer is required we use the Float round because the BigDecimal one is not supported/not working on Hubitat
val = val.toFloat().round().toBigDecimal();
return (val);
def handleDisplayOn(displayOn){
logDebug "handleDisplayOn()"
def result = false
data: [ "state": (displayOn == "on")],
"method": "setDisplay",
"source": "APP"
]) { resp ->
if (checkHttpResponse("handleDisplayOn", resp))
logDebug "Set display"
result = true
return result
def checkHttpResponse(action, resp) {
if (resp.status == 200 || resp.status == 201 || resp.status == 204)
return true
else if (resp.status == 400 || resp.status == 401 || resp.status == 404 || resp.status == 409 || resp.status == 500)
log.error "${action}: ${resp.status} - ${resp.getData()}"
return false
else
log.error "${action}: unexpected HTTP response: ${resp.status}"
return false
Thanks, much appreciated.
Seems like this driver would be able to control other vesync devices (with some new scripts), but since I'm new to this, not sure where to start.
Yes, I think so, at least if they are based on the v2 API. I based my purifier code on this Python repo: https://github.com/webdjoe/pyvesync and then I used Postman to manually validate the APIs.
Let me know if you get more purifiers or humidifiers working, I'd be happy to take a PR.
