Leviton VRE06-1LZ Z-Wave Dimmer Doesn't Update from Digital Inputs
Hi All,
I have a large quantity of Leviton VRE06-1LZ Z-Wave Dimmers and I'm finding a quirk using the Generic Z-Wave Smart Dimmer....
Physical switch changes register back to the hub very quickly and accurately.
Digital changes via Device Control or Homebridge: Change gets sent, executes on the device correctly, but the hub doesn't seem to get the status update that the switch has changed status or dim level changed.
I believe these older Leviton switches use the hail command. I'm not sure if that has anything to do with this or not.
Is there a better driver I should be using? Both Vera and ST played nicely with these switches, so I know there's a way...
Thanks for any insight or ideas, much appreciated!
Jon
