At some point when no one is busy at Hubitat (never )
Can we get a driver for this outlet? The Generic one works just fine but the little green light annoys me, it's on when the switch is off. If it's not programable then I'll live with SOL.
Cheers.
Could use the Zwave Basic Driver to set:
Parameter 7
Size 1
Value 0 = Off
Value 254 = On
I was thinking a little black square of electrical tape
Ah, but that's a specialty item for the Check Engine and TPMS dash LED after the batteries die.
Might work
I confess I have used this “fix” on a Sonoff S31 lite under my sons bed after he complained.
OR you can use the manual and the button.
All Leviton Z-Wave devices can be controlled manually as well as the config parameters.
They did that on purpose.
That was a fail for me until I tried it again today.
Seems the coding is backwards on my firmware. YMMV
Tap twice the LED is on when load is OFF.
Tap once (Default) and the LED is off when load is OFF.
All fixed now.
