Hi all - I too have come across from the mess that is Wink. I have installed an Leviton Dimmer but when it turns on the light is set to 24. (Even when I turn it on at the switch) how do I configure it so that when I turn it on (either through the app or through the physical switch) it’s set to 100
Thank you! I believe it’s the Leviton VRE06-1LZ Vizia. I created a rule that when it turns on it should dim to 100, but that’s seems a little cumbersome
DIM/BRIGhT Bar
BRIGhTEN:
Press right half of DIM/BRIGHT Bar – Lights brighten to desired level. DIM:
Press left half of DIM/BRIGHT Bar – Lights dim to desired level.
If you continue to hold the left half of the DIM/BRIGHT Bar, the lights will DIM to minimum level and then turn OFF.
NOTE: When lights are OFF you can change the
light level that the lights will turn ON to using the
DIM/BRIGHT Bar.
