“Level Lock Pro” Anyone have one?
If so, what driver? I read it was to be in 2.4.2 but I don’t seem to find it.
Generic Matter Lock
However, as I understand, the Level Lock is Matter over Thread (not Matter over Wifi) so it will not connect direct to Hubitat. You need a Thread border router.
Correct. My Level Bolt is connected to a GL-S20 that is connected to Home Assistant and shared with HE via matter integration.
My Apple TV is too old and doesn’t include the thread radio otherwise I would have used it. I tried using an Amazon Echo and it didn’t work for me.
Homepod mini's are cheap
No worries, I have 3 Apple TV and 2 HomePod mini.
The pro version has “door open/close” sensing.
Does anyone know if that is brought into HE as a contact sensor?
Tagging @mike.maxwell
@bcopeland
Late to the party here, but I have mine set up through my Amazon Echo, using the generic matter lock. Works perfectly and gets around the inane Apple Home bullbleep that doesn't allow automated unlocking.
Really no way to know without having one in hand to play with
Does anyone here have a Level Lock Pro?
Wondering about door open/close info.
but no setup option if you dont have an apple tv or iphone.. so not a solution for erveryone
Fair enough
You need to drink the KoolAid :innocent:
[Full disclosure: I own AAPL :smirk:]
Do you have Level Lock “PRO” with door open/closed built-in?
One last try. Maybe someone got the LEVEL LOCK PRO as a Christmas present.
If so, I am very interested in the built in door open/closed sensor and how it works with HE.
Thanks.
Got the Level Lock Pro and added it to Amazon, then HE C-8 Pro. Had to add it as a generic matter lock and it locks/unlocks but it does not bring over the open/close info, at least not that I can see.
Have you tried pairing it to hubitat first?
Level locks require a TBR which Hubitat doesn't currently support. So it must be paired first to an Echo, Google Home, Apple Homepod/TV, HA, etc.
