LED on Jasco Switch
True. Depends on the driver. You want to change parameters on the fly in Rule Machine, and the driver has to have that capability.
Not sure what the built in driver is like nowadays, but Jeff, @jtp10181 , could help.
At one point I had a couple of 700 series Jascos, then wanted to go with 800 series LR Wave, but Jasco was calling them "Pro", and you had to be an installer to get them, expensive, etc. Plus Jasco isn't exactly forthcoming about its stuff. So I went with Zooz. Fewer colors though.
Don't know anything current about the Jascos. I felt build quality was good, and I took a toggle apart. Jasco toggle switches show the colors, where Zooz does not. I made a mod to make the Zooz led "pop".
Here is part of a thread I started on the 700 Jasco.
