LED flashes Red/Green after first time firmware update
While setting up my Hubitat for the 1st time
The app got to the page where it said it needed to update firmware.
After waiting a good 30 mins I came in to the room to find a screen that said firmware update failed.
When I reboot the unit the led turns blue, and then flashed green and red.
When I try the app again it says it finds the unit again at the same IP address but when I look on my network the hubitat is not there.
Eventually the app says it can’t find the unit.
I’ve cycled power several times same result.
Is it a brick now ? Or is there still hope?
Are you using wifi or hard wired?
