@aaiyar, I actually do want to learn the driver side as well and all the zwave/zigbee and whatever else there is to learn here. I know I'm in for some frustration and a steep learning curve. Thanks for the app examples. I went through the building of the app as Adam walked us through in the video, and that worked fine to control the bulb. I want to be able to do it through the driver now.
Ok - can I strongly recommend you start with a simple app, and not a zigbee/z-wave driver. The complexity of the latter is not suited for someone beginning with groovy.
If you're going to do a driver - do a driver for a virtual device.
I'm back with some success from more reading. Using the code below the bulb is turning off correctly but turning it on results in a dimming percentage of 20%. I can rest easy tonight knowing that I will learn this but it isn't easy by any means.
If anyone can help me to understand where that 20% is resulting from I'd appreciate it. I will stop here for now because I want to be able to sleep tonight and my fear is that if I continue I will be up all night.
I think I figured this out as well. It seems it was referring to the 0xFF in the on command which apparently is the factory default brightness setting?
Maybe someone can chime in here.
Thank you for the info and push in the right directions. I know some of you are probably laughing at me but I hope you will be laughing with me eventually.
/ ** A Dimmer **/
metadata{
definition(
namespace: "development",
author: "Adam Kempenich",
importURL: "") {
capability "Actuator"
capability "Initialize"
capability "Switch"
capability "SwitchLevel"
def initialize(){
log.debug "Device initialized."
// Do nothing, since nothing needs to be intialized
def updated(){
log.debug "Device update"
initialize()
def result = null
def cmd = zwave.parse(description, [0x60: 3])
if (cmd) {
result = zwaveEvent(cmd)
log.debug "Parsed ${cmd} to ${result.inspect()}"
} else {
log.debug "Non-parsed event: ${description}"
result
def zwaveEvent(hubitat.zwave.commands.basicv1.BasicReport cmd)
def result = []
result << createEvent(name:"switch1", value: cmd.value ? "on" : "off")
// For a multilevel switch, cmd.value can be from 1-99 to represent
// dimming levels
result << createEvent(name:"level1", value: cmd.value, unit:"%",
descriptionText:"${device.displayName} dimmed ${cmd.value==225 ? 100 : cmd.value}%")
result
def zwaveEvent(hubitat.zwave.commands.switchbinaryv1.SwitchBinaryReport cmd) {
def zwaveEvent(hubitat.zwave.commands.switchmultilevelv3.SwitchMultilevelReport cmd) {
def result = []
result
def zwaveEvent(hubitat.zwave.Command cmd) {
createEvent(descriptionText: "${device.displayName}: ${cmd}")
def on() {
delayBetween([
zwave.basicV1.basicSet(value: 0xFF).format(),
zwave.basicV1.basicGet().format()
], 5000) // 5 second delay for dimmers that change gradually, can be left out for immediate switches
def off() {
delayBetween([
zwave.basicV1.basicSet(value: 0x00).format(),
def setLevel(level, duration) {
sendEvent(name: "level", value: level.toInteger())
sendEvent(name: "duration", value: duration.toInteger())
def toggle(){
log.debug "Toggle Called"
if(device.currentValue("switch") == "on") {
off()
} else {
on()
