Trying to set up a Leaksmart water valve. I discovered it but setup is not complete as it does not operate or follow commands. In the dashboard it is showing a question mark?
Any ideas how to set up
Did you hit the configure button from the device page? I've had this issue too - sometimes the valve does not fully pair before timing out. Try a factory reset on the valve and re-pair then immediately hit the configure button.
I'll try to repair, configure button does not do anything
thanks
Which device type was detected when you added it to the hub? I don't think there's a dedicated LeakSmart driver so you'll probably want to use the Generic Water Valve driver.
I have a Leak Intelligence Leak Gopher water shutoff valve and use the Dome Water Shut Off driver and it works well.
I use the driver posted in this thread. Works well for me.
I use that one too - written by @krlaframboise.
As @SteveV mentions, I think I recall reading that support was added to the generic driver, but yeah, I just use @krlaframboise ‘s driver too.
