Leaksmart Water Valve - lost contact
C7 hub - latest code
The device activity check app said it hadn’t heard from my Leaksmart water valve. I tried to exclude and include it while the unit was next to the hubitat hub and hit the button 1 time, 3 times,etc and could not get it to connect.
I also had bought a brand new unit off of ebay (never used it) …I connected power and that unit is ALSO blinking 2 blue flashes …which they say means it pairing and it will not pair.
I have ZOOZ zwave switches so I know the radio is not down but I kinda think that there is some issue with C7 and this device.
Can some one help me? This is a unit that is plumbed into my water so I really hoping between the 2 of these it should work
sorry I’m an idiot….its a zigbee device
well now even with zigbee neither one connects… one attempt with the newer one said it found a device but then went blank…since then I’ve remove power for several minute, removed the battery and then applied power, the blue light is flashing twice but hubitat will not find it
oddly I did the same thing today and everything worked…i suspect the hub
It’s hard to follow what exactly you’re reporting here.
What do you suspect about the hub?
i could not get 2 zigbee water valves to pair with the hub with repeated attempts.
The next day, both paired fine. The issue was either with the 2 valves or the hub. I suspect the hub. Its just a guess.
Glad to hear your zigbee valves and hub are currently functioning as expected.
