LCM 2.5.142, Code add fails
Trying to add a code for a house sitter, and getting an error
java.lang.NullPointerException: Cannot set property '4' on null object on line 633 (method setCode)
Looks like it succeeded on the lock that only had 2 codes previously (so it set the 3rd code), but on the other two that had a 3rd user, it couldn't set the 4th user.
All locks are Yale with Zwave+ modules.
Nevermind. I ran a configure on the two failed locks, and then it pushed to both of them after a retry. Not sure what the issue was. =(
Sounds like the drivers were missing a critical bit of info to complete..
