As reported in beta bodies of email are missing even though logs show them going out correctly.
As noted previously in the beta, I am experiencing the same issue.
also there are more issues.. something broke the queing.. the state variables being set inside the mutex are not set correctly when one instance runs and another starts up at the same time.. see the following.. this was working in 2.2.3 and 2.2.4
note how it says set last command to initialconnect but immediaately another another instance starts up and it is still getting the value of the last value it was set to "sent ok" this should not be possible..
i believe i have fixed the blank mail issue.. as i summized something in the telnet libraries is stripping off carriage returns or line feeds or both.. i believe smtp needs crlfcrlf to terminate the message..
ie changed this
def sndMsg =[
"MAIL FROM: ${From}"
, "RCPT TO: ${To}"
, "DATA"
, "From: ${From}"
, "To: ${To}"
, "Subject: ${emlSubject}"
, "Date: ${emlDateTime}"
, "${emlBody}"
, "quit"
to this
def sndMsg =[
, "RCPT TO: ${To}"
, "DATA"
, "From: ${From}"
, "To: ${To}"
, "\r\n"
, "${emlBody}\r\n"
, "\r\n"
, "quit"
new version 2.5.8 on github.. test it and see
still issue the the state variables though not being set correctly so multiple messages not getting put in the queue so will be dropped .
i am guessing it is striping off blank lines.. and that is what caused the issue.
happy side note 2.2.5 appears to have fixed delays with ecolink contact sensors
Your update fixed LGK Sendmail v2 email send for me as well! Woot! Thanks for tracking down what changed in 2.2.5 and providing a quick patch for the missing body.
Hopefully HE can help w/understanding why state variables aren't working as expected.
