Anybody else have any issues? Around the time of the latest C7 update the apps stopped. At first I though it was the motion sensors all went out (yes, all at once) than I noticed time based events (like outdoor lights at dusk) stopped. Even switch generated apps dont run. Everything works manually- i can open an app and click Run Actions and it works. But nothing is triggering. Already reset the hub. There have been no device or programming changes in a few months. Just the most recent update.
That is odd. It is fairly unlikely to be the update, but you could roll back (not just a reset, go back a version) if you think it is the cause. I would try to do some diagnosis though because future updates probably won't work correctly either IF the most recent update itself was the cause.
Is there anything in logs tab (past logs) like errors or warnings that point to something not working?
Did you turn on logging for your rules, and when it fails check logs? Post those logs and a screenshot of that same rule so we can compare the logs to the rule.
Which apps are you using, Room Lighting, Motion Lighting, Rule Machine, a community app?
What brands and models are these motion sensors? Zigbee, Zwave, Wifi?
Are you certain that the sensors are triggering? Did you look in the device tab, pick one of these sensors, and then at the top of the settings page for that device look in Events. Are there events that correspond with what the motion sensor is doing?
Sorry, my reply didnt get thrh af first. The motion sensors are triggering, three of them have lights that blink on motion. But none of them are registering at the hub. This happened to all of the motion sensors at one time, so it seems unlikely to be a specific device. I have 9 total, all quit at the same time. They register locally, 4 are also switches and they work locally and under remote control. But all of the Rule Manager Rules that use motion as a trigger no longer operate. I also have 7 scene control switches, they also work locally and can be controlled remotely, but the scene commands (eg: doubletap or hold) no longer work as event triggers. All of the rules are in Rule Manager. I also thought that if several devices failed at once it could be communications- almost all of the network is ZWave. So I did a network repair. It found and fixed some errors, but didnt do much to resolve this problem.
As I noted above, the trigger events arent showing up in ghe logs either. Its almost as if the hub has stopped listening to asynchronous traffic on the network- like its only listening when its doing something.
