I had the opportunity to review this new Presence/Light/Temperature/Humidity from LaFaer (GL Technologies Hong Kong). Current price is $49.99 on Amazon.
I first added it to Apple Home to see if it needed a firmware upgrade. No problem adding it. Firmware reported a simple 1.0 and no upgrade available. I don't like the way Apple Home categorizes things - the device wasn't associated with any room but was in a separate category called security. But I'm not a frequent user of Home.
After resetting the device, I added it to my Hubitat C-8 Pro T without any difficulty. It joined the Hubitat Thread network and it used the driver Generic Matter Motion/Light/Temperature/Humidity Sensor. I'd prefer if it showed the capability as Presence or Occupancy, but using motion when constructing a rule knowing it is really presence worked fine.
It has PIR in addition to mmWave which gives it some help on detecting initial presence, but it took 20-35 seconds to report absence. I later learned this could be fine-tuned in the LaFaer app. I set it to 10 seconds to recognize absence, and it actually cut it down to about 12 seconds.
Light/temperature/humidity reports seemed reasonable, and luminance changes reported in a few seconds.
There is a learning process described in the user manual. I'll experiment with that.
Physically, it is only as big as it needs to be to hold two AAA batteries. The mount consisted of the back panel having a magnetic concave area. There is a half dome part that you affix to something and then the device magnetically snaps into it.
At first, I wasn't going to install the app at all, but glad I did. It finds the device on Hubitat's Thread network so there is no need to remove and re-pair with the app or anything like that. The app gave tuning options such as LED on/off, mode and sensing with PIR and/or mmWave, presence timeout, sensitivity, setting battery type. Nice. The app reported a more specific version 1.0.6.
I suppose this competes with Aqara's FP400, but lacks custom zones, multiperson tracking, and other whistles and bells. But it is half the price of the Aqara, and I do like that it is battery operated and claims two-year battery life.
