Hello @mike.maxwell
Hub FW 2.0.6.112
I just added a Kwikset Zigbee lock and it is generating different values in the events than my older Kwikset Zwave lock. The Zigbee lock does not set digital=true or type=digital for hub commands (it does set physical=false), and the description text is different. More importantly, keypad operations on the Zigbee lock generate two events
Zigbee Manual Unlock
floatValue=0.0,digital=false,unixTime=1552485597857,deviceId=1604,jsonData=null,locationId=null,date=Wed Mar 13 07:59:57 MDT 2019,dateValue=null,id=6967660,numberValue=null,hubId=null,doubleValue=0.0,location=null,descriptionText=Front Door Lock was unlocked by manual,name=lock,physical=true,archivable=true,device=Front Door Lock,value=unlocked,translatable=false,type=physical,unit=null,installedAppId=null,class=class com.hubitat.hub.domain.Event,isStateChange=true,longValue=0,numericValue=null,displayed=true,integerValue=0,data=null,description=null,linkText=Front Door Lock,source=DEVICE,displayName=Front Door Lock
Zwave Manual Unlock
floatValue=0.0,digital=false,unixTime=1552485264335,deviceId=240,jsonData=null,locationId=null,date=Wed Mar 13 07:54:24 MDT 2019,dateValue=null,id=6967469,numberValue=null,hubId=null,doubleValue=0.0,location=null,descriptionText=Veranda Door Lock was unlocked manually [physical],name=lock,physical=true,archivable=true,device=Veranda Door Lock,value=unlocked,translatable=false,type=physical,unit=null,installedAppId=null,class=class com.hubitat.hub.domain.Event,isStateChange=true,longValue=0,numericValue=null,displayed=true,integerValue=0,data=null,description=null,linkText=Veranda Door Lock,source=DEVICE,displayName=Veranda Door Lock
Zigbee Hub Command Unlock
floatValue=0.0,digital=false,unixTime=1552485386200,deviceId=1604,jsonData=null,locationId=null,date=Wed Mar 13 07:56:26 MDT 2019,dateValue=null,id=6967523,numberValue=null,hubId=null,doubleValue=0.0,location=null,descriptionText=Front Door Lock was unlocked,name=lock,physical=false,archivable=true,device=Front Door Lock,value=unlocked,translatable=false,type=null,unit=null,installedAppId=null,class=class com.hubitat.hub.domain.Event,isStateChange=true,longValue=0,numericValue=null,displayed=true,integerValue=0,data=null,description=null,linkText=Front Door Lock,source=DEVICE,displayName=Front Door Lock
Zwave Hub Command Unlock
floatValue=0.0,digital=true,unixTime=1552485215515,deviceId=240,jsonData=null,locationId=null,date=Wed Mar 13 07:53:35 MDT 2019,dateValue=null,id=6967445,numberValue=null,hubId=null,doubleValue=0.0,location=null,descriptionText=Veranda Door Lock was unlocked via command [digital],name=lock,physical=false,archivable=true,device=Veranda Door Lock,value=unlocked,translatable=false,type=digital,unit=null,installedAppId=null,class=class com.hubitat.hub.domain.Event,isStateChange=true,longValue=0,numericValue=null,displayed=true,integerValue=0,data=null,description=null,linkText=Veranda Door Lock,source=DEVICE,displayName=Veranda Door Lock
Zigbee Hub Command Lock
floatValue=0.0,digital=false,unixTime=1552485463897,deviceId=1604,jsonData=null,locationId=null,date=Wed Mar 13 07:57:43 MDT 2019,dateValue=null,id=6967559,numberValue=null,hubId=null,doubleValue=0.0,location=null,descriptionText=Front Door Lock was locked,name=lock,physical=false,archivable=true,device=Front Door Lock,value=locked,translatable=false,type=null,unit=null,installedAppId=null,class=class com.hubitat.hub.domain.Event,isStateChange=true,longValue=0,numericValue=null,displayed=true,integerValue=0,data=null,description=null,linkText=Front Door Lock,source=DEVICE,displayName=Front Door Lock
Zwave Hub Command Lock
floatValue=0.0,digital=true,unixTime=1552485235800,deviceId=240,jsonData=null,locationId=null,date=Wed Mar 13 07:53:55 MDT 2019,dateValue=null,id=6967460,numberValue=null,hubId=null,doubleValue=0.0,location=null,descriptionText=Veranda Door Lock was locked via command [digital],name=lock,physical=false,archivable=true,device=Veranda Door Lock,value=locked,translatable=false,type=digital,unit=null,installedAppId=null,class=class com.hubitat.hub.domain.Event,isStateChange=true,longValue=0,numericValue=null,displayed=true,integerValue=0,data=null,description=null,linkText=Veranda Door Lock,source=DEVICE,displayName=Veranda Door Lock
Zigbee Manual Lock
floatValue=0.0,digital=false,unixTime=1552485666179,deviceId=1604,jsonData=null,locationId=null,date=Wed Mar 13 08:01:06 MDT 2019,dateValue=null,id=6967696,numberValue=null,hubId=null,doubleValue=0.0,location=null,descriptionText=Front Door Lock was locked by manual,name=lock,physical=true,archivable=true,device=Front Door Lock,value=locked,translatable=false,type=physical,unit=null,installedAppId=null,class=class com.hubitat.hub.domain.Event,isStateChange=true,longValue=0,numericValue=null,displayed=true,integerValue=0,data=null,description=null,linkText=Front Door Lock,source=DEVICE,displayName=Front Door Lock
Zwave Manual Lock
floatValue=0.0,digital=false,unixTime=1552485308238,deviceId=240,jsonData=null,locationId=null,date=Wed Mar 13 07:55:08 MDT 2019,dateValue=null,id=6967494,numberValue=null,hubId=null,doubleValue=0.0,location=null,descriptionText=Veranda Door Lock was locked manually [physical],name=lock,physical=true,archivable=true,device=Veranda Door Lock,value=locked,translatable=false,type=physical,unit=null,installedAppId=null,class=class com.hubitat.hub.domain.Event,isStateChange=true,longValue=0,numericValue=null,displayed=true,integerValue=0,data=null,description=null,linkText=Veranda Door Lock,source=DEVICE,displayName=Veranda Door Lock
Zigbee Keypad Lock
floatValue=0.0,digital=false,unixTime=1552485608859,deviceId=1604,jsonData=null,locationId=null,date=Wed Mar 13 08:00:08 MDT 2019,dateValue=null,id=6967668,numberValue=null,hubId=null,doubleValue=0.0,location=null,descriptionText=Front Door Lock was locked by keypad,name=lock,physical=true,archivable=true,device=Front Door Lock,value=locked,translatable=false,type=physical,unit=null,installedAppId=null,class=class com.hubitat.hub.domain.Event,isStateChange=true,longValue=0,numericValue=null,displayed=true,integerValue=0,data=null,description=null,linkText=Front Door Lock,source=DEVICE,displayName=Front Door Lock
floatValue=0.0,digital=false,unixTime=1552485608853,deviceId=1604,jsonData=null,locationId=null,date=Wed Mar 13 08:00:08 MDT 2019,dateValue=null,id=6967669,numberValue=null,hubId=null,doubleValue=0.0,location=null,descriptionText=Front Door Lock was locked,name=lock,physical=false,archivable=true,device=Front Door Lock,value=locked,translatable=false,type=null,unit=null,installedAppId=null,class=class com.hubitat.hub.domain.Event,isStateChange=true,longValue=0,numericValue=null,displayed=true,integerValue=0,data=null,description=null,linkText=Front Door Lock,source=DEVICE,displayName=Front Door Lock
Zwave Keypad Lock
floatValue=0.0,digital=false,unixTime=1552485284049,deviceId=240,jsonData=null,locationId=null,date=Wed Mar 13 07:54:44 MDT 2019,dateValue=null,id=6967488,numberValue=null,hubId=null,doubleValue=0.0,location=null,descriptionText=Veranda Door Lock was locked via keypad [physical],name=lock,physical=true,archivable=true,device=Veranda Door Lock,value=locked,translatable=false,type=physical,unit=null,installedAppId=null,class=class com.hubitat.hub.domain.Event,isStateChange=true,longValue=0,numericValue=null,displayed=true,integerValue=0,data=null,description=null,linkText=Veranda Door Lock,source=DEVICE,displayName=Veranda Door Lock
Zigbee Keypad Unlock
floatValue=0.0,digital=false,unixTime=1552485656004,deviceId=1604,jsonData=null,locationId=null,date=Wed Mar 13 08:00:56 MDT 2019,dateValue=null,id=6967691,numberValue=null,hubId=null,doubleValue=0.0,location=null,descriptionText=Front Door Lock was unlocked,name=lock,physical=false,archivable=true,device=Front Door Lock,value=unlocked,translatable=false,type=null,unit=null,installedAppId=null,class=class com.hubitat.hub.domain.Event,isStateChange=true,longValue=0,numericValue=null,displayed=true,integerValue=0,data=null,description=null,linkText=Front Door Lock,source=DEVICE,displayName=Front Door Lock
floatValue=0.0,digital=false,unixTime=1552485655993,deviceId=1604,jsonData={1={code=, name=master}},locationId=null,date=Wed Mar 13 08:00:55 MDT 2019,dateValue=null,id=6967690,numberValue=null,hubId=null,doubleValue=0.0,location=null,descriptionText=Front Door Lock was unlocked by master,name=lock,physical=true,archivable=true,device=Front Door Lock,value=unlocked,translatable=false,type=physical,unit=null,installedAppId=null,class=class com.hubitat.hub.domain.Event,isStateChange=true,longValue=0,numericValue=null,displayed=true,integerValue=0,data={"1":{"name":"master","code":""}},description=null,linkText=Front Door Lock,source=DEVICE,displayName=Front Door Lock
Zwave Keypad Unlock
floatValue=0.0,digital=false,unixTime=1552485296300,deviceId=240,jsonData={1={code=, name=Master}},locationId=null,date=Wed Mar 13 07:54:56 MDT 2019,dateValue=null,id=6967493,numberValue=null,hubId=null,doubleValue=0.0,location=null,descriptionText=Veranda Door Lock was unlocked by Master,name=lock,physical=true,archivable=true,device=Veranda Door Lock,value=unlocked,translatable=false,type=physical,unit=null,installedAppId=null,class=class com.hubitat.hub.domain.Event,isStateChange=true,longValue=0,numericValue=null,displayed=true,integerValue=0,data={"1":{"name":"Master","code":""}},description=null,linkText=Veranda Door Lock,source=DEVICE,displayName=Veranda Door Lock
