when i program a code through the device panel it comes back with the wrong code shown in the data.. however, the correct code i just added does work in the lock.. in addition, fetch is returning the wrong codes as well. Same driver with older non zigbee 3.0 cards return the correct codes.. any idea what is going on.. is the code data being returned in a different order for zigbee 3.0 calls?
Have you tried it through Lock Code Manager?
What release are you one? Are you a beta sub?
If it fails in the built-in app then you can tag the guys directly.
I'm not sure the support tag goes anywhere quickly, just my gut feeling.
