I paired my Kwikset Convert module to HE (seemed to work) with the idea that I would swap out the old Z-Wave module (non-plus) in my Kwikset 910. But then I ran into issues:
I could not get it to accept lock codes from the device page. The process I followed was - a) Hit "configure" b) enter code position, PIN code and name c) hit "save preferences". No lock codes would show in "Current Status".
I figured I would swap the Z-Wave module with Zigbee and try programming from the keypad and I could not get the Z-Wave module out of the old lock. The Zigbee module slides right out of the lock assembly, so do I need to physically remove the old lock assembly before I can remove the Z-Wave module?
I tried to "exclude" the Zigbee module from HE (the one I had paired in Step 1) and whatever I do (press "B" 9 times or try and factory reset) does not seem to remove the lock.
Any thoughts on what I can try or steps that I'm missing? Thanks for your help
EDIT: Attaching the device details from the HE device page in case I'm missing something there.
