My Kwikset is working and was functioning by sending and updating codes. I also have an auto-lock set when my door is closed. So my Hubitat is still communicating correctly.
I did try to send new codes and I get a fail message
I tried to update codes and I also got a fail and the old code stopped working
I am not sure when it started, I am assuming it was after a software update to my Hubitat,
I am using Lock manager.
@creativedata Start by shutting down your hub from the settings menu. Unplug Hubitat at the wall (not at the hub) for 5 mins then power back up. See if that clears it. A software update likely wouldn't change that unless it were a driver issue and it's been a long long time since those lock drivers have been changed.
Have you updated the z-wave stack? This is separate from the platform update. You can check if your unsure by going to your z-wave details page and looking at the top for the z-wave firmware update button. If it's not there your hub is updated.
