KONOzw thermostatOperatingState : heating
thermostatOperatingState : cooling command passes fine but not the thermostatOperatingState : heating does not.
Is this a ZW+ Driver issue OR Controller App? - Thank you very much in advance for any help!
Please post a screenshot of you Thermostat Controller setup page.
Hi Bruce - I can not upload snapshot/links yet, but please see the link to the Controller settings below - Thank you very much in advance for your help!
Current States
control : controlled
controlOffset : 0.25
coolingSetpoint : 79
heatingSetpoint : 78
hysteresis : 1.0
supportedThermostatFanModes : ["on", "auto"]
supportedThermostatModes : ["auto", "off", "heat", "cool"]
switch : on
temperature : 75.2
thermostatFanMode : auto
thermostatMode : auto
thermostatSetpoint : 78
Is thermostat zigbee?, or z-wave...
Konozw is zwave+. Should work with a generic zwave+ driver. Don’t know which driver @HubiTex is using.
Hello Mike, I am using the "Generic Z-Wave Plus Thermostat" driver - Thanks.
With the "Generic Z-Wave Plus Thermostat" driver Cooling works but not Heating, The Konozw does not change "thermostatOperatingState" - I can control the Konozw Heating from the Thermostat device screen on the Hubitat.
I think this is a Thermostat Controller App issue.
Ok.. I'm a bit confused here.. The current states you show above show thermostatOperatingState: heating..
I must be missing something.. Also could you turn on debug logging on the thermostat device page and capture the log of what happens?
Hi Brian - "thermostatOperatingState: heating" shows on the Controller, however the Konozw does not change state from "Idle". I can change the state manually from the Konozw Devide window. However, when the thermostatOperatingState: cooling" shows on the Controller, the Konozw changes to "cooling".
I will turn on the log and paste any information provided here. Thank you very much for your help!
Joining the Owner's group fixes that...Hubitat Community Groups
