I'm using a Konnected Pro panel and controlling it through Hubitat, all my zones are there and working correctly with HSM, but when the alarm is armed and triggered by a sensor, the siren only sounds whilst the sensor is active, ie only sounds when the PIR senses movement, then goes off, then on again etc. It should sound continuously for a period after the first sensor trips, but I can't find the setting for it, or figure out what I've missed.
I know it works correctly as I have been using it with Smartthings and it worked as expected.
Any help for a newb would be appreciated.
