Using a Konnected Pro 12 port board with my Hubitat since 2019 when I had a C-5.
Using a C-8 since 2023 with no problems.
Planning for a change of WiFi Router from Synology RT2600ac to the WiFi in Starlink. I have Starlink in Bypass mode.
The Starlink router is very basic, like no network configuration controls and using local IP in 10.0.x.x range vs 192.168.1.x I've been using. A Reddit post claims that Starlink will leave devices with low octet address below 10 alone. So, I'm thinking of moving my major fixed IP addresses to rational reservations rather than telling the router to add its randomly assigned IP to the reservation list as I've always done.
In any event, I cannot find a way to change the IP address of my Konnected Pro board in Hubitat. As noted in the first line, my setup is OLD. Hubitat has changed a lot over the years.
I have in Apps:
And clicking to the device:
The device screen shows:
With no way to alter the IP address visible in the Hubitat HMI.
In Devices, I have individual wired devices for the zones such as: "Konnected Motion Sensor".
What I don't know is how a Konnected Pro board would be newly set up with the current Hubitat software (I'm running 2.5.1.143). I know I could delete the existing device and add it back, but will require redoing a lot (all of HSM for example).
I could stay with my current router, but Starlink supports WiFi 6 & 7 which mine does not.
Any ideas?
Thanks,
SK!
