Konnected Integration not going well
I moved over all the devices from ST and...Houston, we have a problem. I'm a Konnected user. I removed everything from ST, I installed the Konnected service manager and the needed drivers (Konnected Beep/Blink, Konnected Contact Sensor, Konnected Motion Sensor, andKonnected Siren/Strobe) from Github. HE recognizes my boards (1+1 addon V1) and I configured the pins in the HE GUI. The devices populate system.
Problem: Only the siren and the beeper (Output on main board and addon board, respectivly) have any functionality. I deleted devices, re-inputed the pins in the App and i get the same thing. In the Dashboard, the icons come up as questionmarks. I each device info page, the current status is blank, no logging available. I searched thouroughly across the interwebz and found little related to this and what I did find didn't help. I consulted with the Konnected people. I'm attaching some screen shots of the GUI. I now present this to you for help and perhaps I can get this resolved soon Thanks in advance for all the helpers in this community.
Another thing to note, the Konnected iOS app service tool cant find its devices but I can turn Siren on and Beep the beeper in HE.
Tagging @nate from Konnected to see if he will chime in.
You may get a quicker response from the other Konnected users over in the Konnected Community forum.
I started from scratch again and I fixed it. I don't know how but it works. Something was corrupted or something, who knows. :grinning:
It was a trial and error process for me as well. But once I got everything set up correctly, it has been flawless since then.
do you have multiple motion sensors only 1 of my 2 seem to work..
Only one hubitat. I have some in Arlo, have homebridge and have Rules in HomeKit.
I have 3 hardwired.
weird both of mine are hardwired and could never get the kitchen on working.. i see the light flashing so it is working and if i swap the two on the board it works.. so must be a bad port of the board..
Try a door sensor on that one and see.
