Konnected advice
Hi guys. So I've set up Konnected and I'm really impressed so far. I was wondering how you guys use it with HSM or RM etc. How do you configure your dashboards for armed/ activated etc. Any advice is appreciated as I'm looking for general ideas
I use the Konnected motion detectors for motion lighting rules, the contacts to turn lights on when opened and off when closed, I also have most of the contacts, some of the motion, all the water sensors and sirens in HSM which I have it arm and disarm with presence and when we are in bed. The water sensors automatically close the Sinope water main if they detect water as well as alert us. I also have a temperature probe in the main freezer, and a temp/humidity sensor which I use to automate a bathroom fan.
Just curious, do the Konnected inputs and outputs show up as regular contact sensors and switches in the device manager? Wondering if they could be used as generic dry contact inputs, for example, to trigger other rules, etc.
Yes. That is one of the ways that I use my Konnected devices. I use webcore to manage the HSM side of things. I had that set up already when I moved over from ST.
