I recently connected a Keen Smart Vent to my Hubitat using the built-in 'Keen Home Smart Vent' driver. I can set the level (using both Apps and a Dashboard tile), and the vent adjusts relatively as expected. However, Hubitat does not show the vent level unless I manually run the refresh command.
This is an example of the debug log output for the device. In this case, I changed the level from ~20% to ~60% at ~14:38. No log messages were printed until I manually ran the refresh command.
dev:643 2019-10-09 14:46:40.408 info MySmartVent level was set to 58%
dev:643 2019-10-09 14:46:40.283 info MySmartVent battery is 100%
dev:643 2019-10-09 14:46:40.279 debug descMap:[raw:22E50100010A21002064, dni:22E5, endpoint:01, cluster:0001, size:0A, attrId:0021, encoding:20, command:01, value:64, clusterInt:1, attrInt:33]
dev:643 2019-10-09 14:46:40.274 info MySmartVent is on
dev:643 2019-10-09 14:46:40.270 debug descMap:[raw:22E50100080A00002096, dni:22E5, endpoint:01, cluster:0008, size:0A, attrId:0000, encoding:20, command:01, value:96, clusterInt:8, attrInt:0]
dev:643 2019-10-09 14:46:40.226 debug descMap:[raw:22E50100060A00001001, dni:22E5, endpoint:01, cluster:0006, size:0A, attrId:0000, encoding:10, command:01, value:01, clusterInt:6, attrInt:0]
dev:643 2019-10-09 14:46:38.849 debug refresh...
