Kasa "non matter" devices not on compatability list anymore?
I bought a TPLink 505. H found it with no problem and it works perfectly. None of my 6 other Kasa switches are working. I haven't tired the rediscover suggestion. I'll have to figure out the exact steps for that. Weird that all my Kasa plugs are fine and only my switches have gone stupid.
It is not the integration. It works on my C7 and C8 Hub. It is likely something not done during installation a long time ago. Open the Kasa Integration App and click the ? in the upper right corner. This will go to the documentation. It is sometimes dated. Also, make sure each device has a DHCP reservation (reserved IP address) and if you change routers, you must do this again.
PS - I wrote both the Kasa and the TP-Link Tapo Integrations. They use similar methods for device discovery and management (although different device security and API).
So I removed Kasa Integration and then reinstalled it an now everything is seen and works. I'm not sure why I didn't try that earlier and I have no idea what happened. But it works so I'm leaving it alone!
Thanks again for the help Dave. You are an awesome resource.
