Kasa FW 1.1.0 for switches
As of FW update 1.1.0 the Kasa Integration no longer works to add or control switches. The devices that have been upgraded are not available in the app and they are also not available in the Tapo 3rd party integration. This is the error from Tapo - Found Unsupported Devices: [HS210(US):DevType IOT.SMARTPLUGSWITCH not supported]
Is there a plan to upgrade the Hubitat Kasa native integration to fix this? I now have 3 lights and possibly more to come that are no longer controllable. For clarity the 1.1.0 update appears to remove the connection to the device on port 9999
Tagging @bcopeland for comment.
You could also revert back to a previous known working build to get things back on track.
Once the kasa device firmware auto updates, i see no way to revert back to a previous version.
That was my mistake. I read it the the latest HE update had caused the issue, not the Kasa update.
Plan in place. Almost done. However, I had this happen to me on another device with same issue. Possible fix for now (did trick for me):
  • in the Kasa/Tapo phone app, uninstall the device (do not uninstall from Hubitat if installed),
  • Wait 1 minute
  • Reinstall in the KasaTapo phone app
  • Wait 1 minute
  • Try hubitat command (or install)
Will give this a shot tonight when back home. I had one more switch upgrade over night too so i think its only a matter of time before all of them are broken. Then I have to turn off lights with a switch like a peasant again :smile:. Looking forward to the new release with support for the latest fw.
you can turn off auto upgrade.. i havent upgraded any of mine.
hubitats latest update supports the new firmware and Tapo devices .. but only on their newest hub. What a joke. Anyone found a 3rd party integration that works?
First - TONE. What a joke is an insult!
Second - What do you mean?
Still need more information to resolve your issue. I read your statement as you having two hubs. It works on one and not on the other. What are the HW models and FW version of your two hubs.
If that is not the case, what can you provide to trouble-shoot.
I am the developer of this integration as a community contributor (without compensation). This version of the integration was developed on A C-7 hub running an early 2.5.1 through 2.5.3 (early Beta). Validation was on several versions of a C-8 hub (to test legacy transition). I do not have a C-4 nor C-5 hub (earlier hubs) but the code does not work only on the :newest hub.
Dave
