I just discovered this. Functional seems to be unaffected. Single Kasa wall switch.
Generally, this is caused by you device being not reachable. Either power is removed from the device's source or the device's IP has changed. I can not go further without the device model.
Things to check:
- Open the Kasa Phone app and determine if you can control the device via that app.
- Check and make sure that a Static IP address (DHCP) in your router is set for the device.
- Try running the Hubitat Kasa Integration app through discovery (this will update the device IP address if the device is reachable).
To go forward, need the following (from the Kasa Phone App:
- Model
- Hardware Version
- Firmware Version
Will do that and report back
