Hi all, I've updated my Kasa Integration app to the latest version using the Package Manager and I noticed that all of the sudden all Kasa devices have been spamming HE with logs.
I've followed the instructions and reduced the 'Event and State' history size but the issue still persists even after clearing the events and rebooting the hub - All the devices had been working as expected before I updated the app so I can't think of anything else here.
If it's the logs that are bothering you look for the field called "Enable description text logging" or similar in preferences and uncheck that. The event logging is separate. But I think your problem is not specifically that.
I haven't updated mine to the latest, I think I will try that now and see what happens to me. However I have Cloud Binding disabled, and the device is just a lightbulb, so I might not have the same problems
Edit: Yep. My option to disable text logging has disappeared too I have reported this in the app's thread
I am not too sure what else to do, I've just cleared the events and rebooted the hub again but 27 minutes later I am already getting the same alert and all 4 Kasa devices are on the top of the list:
Don't worry @hpgurgel, I worked through this myself, I'll give you a hand.
To start with, please disable the Energy monitoring Preference Setting for each plug that supports this and restart your HE hub. You can use the Preference Manager built-in app if you have quite a few plugs, otherwise, just adjust them manually.
They will be temporarily, but it shouldn't be for too long.... all going well.
Don't worry about Pref. Manager, was only a suggestion if you had a lot of plugs, work through them one at a time updating this preference if you need to.
Probably worth getting through your immediate issue without complicating things for now, just may be worth introducing once you are back up and running
@thebearmay can probably comment better than me on your error, but GitHub can have issues from time-to-time..... Or the config for a "package" can also be slightly off occassionally.... Like I said, probably one for tomorrow I expect, best to make sure your system is up and running for now.
