- Kankun Wifi Outlet (Outlet Must Be "Hacked" according to instructions Below)
- Copyright 2015 Krys Allen
- Licensed under the Apache License, Version 2.0 (the "License"); you may not use this file except
- in compliance with the License. You may obtain a copy of the License at:
* Unless required by applicable law or agreed to in writing, software distributed under the License is distributed
* on an "AS IS" BASIS, WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied. See the License
* for the specific language governing permissions and limitations under the License.
* The Kankun Wifi outlet ships with some smartphone app control, however someone smarter than me realized it was running
* openWRT and put out a hack to make it very easily joined to your WAN and controlled via HTTP.
* Follow the document here to get the outlet joined your WAN https://drive.google.com/file/d/0B3zmQ6SwYdyJeEdlc2V2S2VoRzg/view
* Then use this guys JSON code to set up the outlet for HTTP. [GitHub - homedash/kankun-json: A CGI script that provides a simple web interface and RESTful JSON API for the Kankun Small K wifi switch.](https://github.com/homedash/kankun-json)
* Then this device type should work.
preferences {
input("ip", "string", title:"IP Address", description: "10.1.1.185", defaultValue: "10.1.1.185" ,required: true, displayDuringSetup: true)
input("port", "string", title:"Port", description: "80", defaultValue: "80" , required: true, displayDuringSetup: true)
metadata {
definition (name: "Kankun Wifi Outlet", namespace: "allen00se", author: "Krys Allen") {
capability "Switch"
capability "Polling"
capability "Refresh"
simulator {
// TODO: define status and reply messages here
tiles {
standardTile("switch", "device.switch", width: 2, height: 2, canChangeIcon: true) {
state "on", label: '${name}', action: "switch.off", icon: "st.switches.switch.on", backgroundColor: "#79b821"
state "off", label: '${name}', action: "switch.on", icon: "st.switches.switch.off", backgroundColor: "#ffffff"
standardTile("refresh", "device.power", inactiveLabel: false, decoration: "flat") {
state "default", label:'', action:"refresh.refresh", icon:"st.secondary.refresh"
main "switch"
details(["switch","refresh"])
//tiles {
// standardTile("button", "device.switch", width: 1, height: 1, canChangeIcon: true) {
// state "off", label: 'Off', icon: "st.switches.switch.off", backgroundColor: "#ffffff", nextState: "on"
// state "on", label: 'On', icon: "st.switches.switch.on", backgroundColor: "#79b821", nextState: "off"
// TODO: define your main and details tiles here
//main "button"
// details(["button"])
// parse events into attributes
//log.debug "Starting LAN Parse"
def msg = parseLanMessage(description)
//log.debug "msg: ${msg}"
def json = msg.json
log.debug "JSON: ${json}"
//if (json['ok'] == 'true'){
// log.debug "Set command was Successful!"
//} else {
// log.debud "Set command failed!"
if (json['state'] == 'on'){
log.debug "Outlet is On"
sendEvent(name: "switch", value: "on")
} else if (json['state'] == 'off'){
log.debug "Outlet is Off"
sendEvent(name: "switch", value: "off")
} else if (json['ok'] == true){
} else {
log.debug "Command Failed! Result: ${json['ok']}"
def poll() {
log.debug "Executing 'poll'"
myCommand("get=state")
def refresh() {
log.debug "Executing 'refresh'"
private setDeviceNetworkId(ip,port){
log.debug "IP:${ip} Port:${port}"
def iphex = convertIPtoHex(ip)
def porthex = convertPortToHex(port)
def hexVal = "$iphex:$porthex"
device.deviceNetworkId = "${hexVal}"
log.debug "Device Network Id set to ${hexVal}" //:${porthex}"
return hexVal
private String convertPortToHex(port) {
String hexport = port.toString().format( '%04x', port.toInteger() )
return hexport
private String convertIPtoHex(ipAddress) {
String hex = ipAddress.tokenize( '.' ).collect { String.format( '%02x', it.toInteger() ) }.join()
return hex
def myCommand(value) {
def hexValues = setDeviceNetworkId(ip,port)
log.debug "Running myCommand with values:${value}"
def myCommandAction = new physicalgraph.device.HubAction(
method: "GET",
path: "/cgi-bin/json.cgi?${value}",
headers: [
HOST:"${hexValues}"
log.debug("Executing hubAction on ${hexValues}") // + getOutletAddress())
//log.debug "Result: ${myCommandAction}"
myCommandAction
def on() {
log.debug "Executing 'on'"
myCommand("set=on")
// TODO: handle 'on' command
def off() {
log.debug "Executing 'off'"
myCommand("set=off")
// TODO: handle 'off' command
