hi all, ive had a bit of trouble setting up scenes, I found that it wasn't turning everything on or selecting the correct colours, I worked this out without having to look silly, basically if youre having this issue t first port of call would be going back into the scene in apps and then scrolling down to adjust scene, you would think that capturing the scene would be enough, but in my instance I have multiple device types, so it not just a simple on off, I found when I wasin the adjust page that when I captured it some of the saved actions were completely incorrect, once id changed these and resaved the scene, it worked perfectly, not before id wasted an hour ! anyways I hope this helps anyone with similar trouble, I know this is very basic for most of you, but im still learning.
There is a current bug in Scenes where a scene with lights in CT mode will not report the status correctly. It will show as "not set" even when it is. Fix is coming in 2.1.6. Don't know if that is what you meant but thought I'd mention it to save you another possible headache.
No I mean that when you capture a scene it doesn't always capture it correctly, took me a while to work it out, I know about the ct bug, it's quite annoying, I'm hoping a fix is out soon
Latest release that came out today...it's all fixed.
I've had the same when I would set scenes in the Philips Hue app and then capture them with Hubitat. That was because it takes some time (default one minute) for the Hue bridge to sync with Hubitat.
Don't know if this is happening to you, but I thought I'd mention it to save you yet another possible headache...
I'm connected directly with all my items, there's nothing on a bridge, I've had a similar thing happen when I've forgotten to press the config button when changing driver.
