I'm getting the following error when calling JsonSlurper from my driver's parse() method:
2019-11-16 12:30:51.944 pm [error] groovy.lang.MissingMethodException: No signature of method: user_driver_jem_Pixelblaze_Controller_563.parse() is applicable for argument types: (groovy.json.internal.LazyMap) values: [[vars:[PCP_PACKET:[0, 0, 0, 0, -1]]]]
I remember this working a couple of Hubitat updates ago, and I didn't notice the exception 'till now, because I had commented out the method that asked the device for a json-ized list of its internal variables.
The driver is still clearly calling parse() when it gets a packet - the section that deals with the binary frames of pattern id data is working fine.
What am I missing here? Do I somehow need to specify namespace for JsonSlurper when in a callback? Did they change parse() so it automatically gets called with a map parameter when it gets recognizable json? For the moment, I'm kinda stumped.
Here's the code, which is called in response to any packet arriving via the websocket connection. (Edit: The relevant portion starts with the "else if" about halfway down. I know we're getting there because the "JSON getVariables frame detected" always shows up in the log.)
def parse(String frame) {
// determine what kind of frame it is. Variable lists come in as JSON
// strings, program lists are hexStrings, with a signature 0x07 as the
// first encoded byte.
if (frame.startsWith("07")) {
logDebug "Found program list binary frame"
// convert the data portion of the hex string to a normal string
def byte[] listFrame = hubitat.helper.HexUtils.hexStringToByteArray(frame)
def rawList = new String(listFrame,2,listFrame.length - 2)
// since program listings can be spread across multiple frames, we need to check
// for start and end frame tags, which are in the second decoded byte
if (listFrame[1] & 0x01) { //look for 0x01 start frame indicator
logDebug "Start Frame Detected"
state.patternList = [ : ]
if (listFrame[1] & 0x04) { // look for 0x04 completion frame indicator
logDebug "End Frame Detected"
// convert list entries into a map, indexed by pattern name
def newMap = rawList.tokenize("\n").collectEntries {
it.tokenize("\t").with {[(it[1]):it[0]]}
state.patternList << newMap
else if (frame.startsWith("{\"vars\":")) {
// The frame contains exported variables
// from the currently running pixelblaze pattern.
logDebug "JSON getVariables frame detected"
json = null
try {
json = new groovy.json.JsonSlurper().parseText(frame)
if (json == null){
logDebug "JsonSlurper failed (null result)"
logDebug frame
return
catch(e) {
log.error("Exception while parsing json frame: ",e)
log.error frame
return
logDebug json // TBD - do something fun with this data!
