Java Null Pointer error on Rule Machine Rule
I have setup several rule machine rules and most of them work fine. However I have one that is set to run 30 minutes after SunRise, and it always fails with "Cannot invoke method getAt() on null object on line 6825 (allHandlerT)".
This is the only one that is set to run using Sunrise (others are based on TimeOfDay or +/- Sunset).
I upgraded to the latest & greatest version of the Elevation Platform (2.2.4.158 from 2.2.4.1??) yesterday, but same error this morning.
The device is a Bali Shade using the Generic Z-Wave Shade Driver, I can control the shade manually with no issues, and a rule to close before Sunset works fine.
I have 2 of them, the other one works fine (set to open at a Specific Time Of Day and to close before Sunset).
Any Ideas?
Posted/moved to correct area (Rule Machine)
Show a screenshot of the rule.
I tried (a couple of different ways) All I get is an error (Cannot embed media items in post).
Screenshot of rule:
Please post a screenshot of the Application State portion of the App Status page for the rule (gear icon upper right).
You might try removing that rule, and recreating it. See if that fixes it... Otherwise, I'll dig into it..
App State Portion:
Changed rule from after Sunrise to a specific time of day, it still wouldn't trigger.
on 12/31 deleted and re-created rule.
Deleting & Re-Creating rule fixed the issue.
