I had my first switch failure. I have two Jasco/GE devices. One is a Smart Switch and one is a Smart Dimmer (the ones with the paddles). They have been reliable for several years. We had a power outage. When the power came back on, I found that the switch was no longer responding. Not only that, but I can't even turn the ceiling light fixture it controls on or off.
The switch has an LED light. It is blinking. It isn't the solid color it should be if the switch were turned off nor the blinking pattern it would show if it were in pairing mode. It is a steady blinking. I tried the ten presses of the switch the instructions specified to put it in pairing mode, but it does not work. I tried cycling the power to that circuit but that did not help either. I think something in the switch died. Has anybody had anything similar happen? If so, is it something that can be fixed?
I have a replacement on order. The replacement with be a GE Enbrighten switch which seems to be the newer version. However, if I can fix the old one, it would be nice to put it to use also to automate another light.
