Hi there community!
I have an older Jasco ZW3005 Z-Wave dimmer installed in a room. Manual actuation of the paddles works fine. I have the device setup in HE, and have tried several drivers. I can actuate the dimmer just fine via homekit, but if I manually toggle the dimmer, the state doesn't update in HE, Alexa or Homekit. I know that if HE isn't updating state the other two won't either.
I've even tried a couple drivers in the community, like @Botched1's GE/Jasco Dimmer driver.
Also - I have a rule that turns on/off a couple plugs when this device goes on/off. if I actuate it in Homekit, or HE, the rule works fine. If I manually toggle, nothing. I've even tried the generic Z-wave dimmer driver, to no success.
Any ideas here? Hate to rip/replace for a driver problem.
(I've seen this recently with other GE/Jasco products and the incorrect driver, but the generic driver usually fixes the issue) TIA
