This have been an on going event for a long time, just keep forgetting to post about it unless I see it as it happens in the Logs.
Everything works just fine, but the Log gets flooded.
I'm only using one of the outlets for two led landscaping lights. Here is what I have going on.........
Here is the single outlet in use........
When the Sunset timer turns on the outlet this is what you first see......
Here is what follows....................................................
I see the problem in the code.. but it would take longer than I have to fix it... Plus I don't have one of these to test with... (ep=null so it is basically just looping and requesting the same report as it got over and over again)
def zwaveEvent(hubitat.zwave.commands.switchbinaryv1.SwitchBinaryReport cmd, ep = null) {
log.debug "SwitchBinaryReport ${cmd} - ep ${ep}"
if (ep) {
def event
def childDevice = childDevices.find {
it.deviceNetworkId == "$device.deviceNetworkId-ep$ep"
if (childDevice) childDevice.sendEvent(name: "switch", value: cmd.value ? "on" : "off")
if (cmd.value) {
event = [createEvent([name: "switch", value: "on"])]
} else {
def allOff = true
childDevices.each {
n->
if (n.deviceNetworkId != "$device.deviceNetworkId-ep$ep" && n.currentState("switch").value != "off") allOff = false
if (allOff) {
event = [createEvent([name: "switch", value: "off"])]
} else {
return event
} else {
def result = createEvent(name: "switch", value: cmd.value ? "on" : "off", type: "digital")
def cmds = []
cmds << encap(zwave.switchBinaryV1.switchBinaryGet(), 1)
cmds << encap(zwave.switchBinaryV1.switchBinaryGet(), 2)
return [result, response(commands(cmds))] // returns the result of reponse()
But you could comment out that section until a fix is posted..
We don't even support those switches anymore. They are grandfathered in but what @bcopeland posted would be the fastest fix.
Find the section and add /* at the beginning and */ at the end.
Like this...
if (ep) {
def event
if (cmd.value) {
} else {
def allOff = true
childDevices.each {
n->
if (allOff) {
} else {
return event
} else {
def cmds = []
@anon61068208 @bcopeland Does this look correct?
Yep.. That should do until someone fixes the code... You wonโt get proper status updates.. But you wonโt be in an endless loop
ericm
April 3, 2020, 11:12pm
10
Took me a while to get to this because I couldn't find my NZW97 (it has been discontinued). I finally found it this afternoon and updated the driver to reduce the network traffic.
system
Closed
September 22, 2022, 5:48pm
11
