Issues Updating to 2.3.9.2XX
I've had an ongoing issue upgrading the platform on my C7 to 2.3.9.2XX. The long and short of it is that the hub would get stuck at "25% updating device drivers" and then cycle back to a reboot. The only way I could get it back working was a downgrade to 2.3.7.146.
Well...today, I finally fixed it! Not sure what is going on, but this is what I discovered.
The database, somehow, was causing an issue. I hesitate to say "corrupted" because it worked in 2.3.7.146. I had 2 devices (Z-Wave) that I only use around Christmas to control lights, so they are off the network most of the time. I also had a switch, that I'm in process of moving around the house, so it, too, was in the database, but not actually in the network. I removed the uninstalled switch, and plugged in both of the other two devices, so that I didn't have any more ghost devices. Then I went through all my custom code and deleted drivers and apps I'm not using, and updated drivers that I could from posts.
After that, I did a platform upgrade from 2.3.7.146 to 2.3.9.201. It did do a couple of restarts, but eventually it got all the way through and is up and running.
I've been operating with ghost devices for a while, and never had an upgrade issue before. I don't know if it was those ghost devices, out-of-date drivers and apps, or unused drivers and apps, but something in those categories caused the upgrade to fail.
I hope this helps anyone who has similar issues, and maybe the developers to find the bug.
If for no other reason, get rid of the ghosts for the sake of your mesh...
