Issue since power outage
So we had a power outage about a week ago. I have my hub on a UPS and was able to shut it down when the power went out. Since it came back up my master bathroom light is very intermittent as to when it will work properly. It's set to come on based on motion. I decided to look at routing for that switch (a Zooz double switch) and it had a crazy route. So I ran REPAIR on that node. The majority of times it comes back as unreachable. One time it was able to ping it but then I got:
2022-07-26 04_46_47-Z-Wave Details - Brave
The path it's taking is from my hub to a Hank button remote control (didn't even know they were repeaters), to a Aeotec Zwave extender that is closer to the hub than the Hank.
I guess I can move the extender or maybe I need another. My place is only 1200 sq feet and the hub is pretty close to the center. Any other ideas how to get the rebuild to work?
Also at the bottom of the Zwave list I have:
No clue what those are. How do I figure that out? Or should I just refresh until I can remove them?
Thanks!
Could try discover to try and get them to complete there join and configuration. Watch the logs it will tell you if they connect
I'd assume the device, whatever it is, it long out of pairing mode. But it can't hurt.
It's already paired just not completed so the paring mode is not normally required (at least for powered devices). When I have fixed these once it gets the message it jumps back to life and configures.
:crossed_fingers:t2:
Didn't help those and I don't see any missing so I just removed them. Also decided since I'm not using the Hank button controllers, I had 2, to just remove those as well since they are repeaters. Will see if things behave better with all those changes made.
They should they're ghosts. Removing them is the best option.
