Is there an easy way to "test" a simple automation rule?
I have started using Simple Automation Rules instead of Rule Machine - is really is much easier and more straighforward.
Is there an easy/quick way to test the actions of a simple rule (similar to the run actions in rule machine) ?
You can always add an extra virtual device to your app so that you can ā€˜force’ a change
Then if everything works as you expect, you can remove the virtual device
Andy
